This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
I don't know what range rpms it is fouling, but if its fouling at 4000 and above (well above the transition) then, besides the float level, you might check the press-in main air jet. With the carb right-side up, it is at the 4 o'clock position. If that air bleed is plugged, the main jet will use gasoline at a higher rate.
Originally posted by MAXIMAN If only your #4 plug is fouling the odds are something is wrong with the #4 carb. Float level too high ...etc.
