Moisture in Oil
    Makes me thankful to be livin' where I do.........none of these moisture problems exist with the drier climate, neither internal or externally. Just polish the nice original chrome all up occassionally, fill up the non rusty tank, and twist the righ thand hard...........wa-la, XSheaven.........yeppers.
    • BLUEJEEPLAB
      • Sep 2005
      • 703
      • Miami Valley, Ohio
      Succubus, Is your last name McGiver?
      Papa Gino
      79 and something XS 1100 Special "Battle Cruiser"
      78 XT 500 "Old Shaky"
      02 Kawasaki Concours "Connie"
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        What happens to the stoichemetric ratio when you hist 4 atm below the water surface?
        • BLUEJEEPLAB
          • Sep 2005
          • 703
          On any other bike, the idea is to let go before you hit 2 ATM, but with the value of the XS, all attempts should be made to stay with the bike to facilitate recovery. There are always decpmpression chambers and major medical insurance....
          Papa Gino
            Those depths are beyond recreational diving!
            • Brent
              • 959
              water in oil
              Originally posted by ZXDavid
              One thing that causes that is starting your bike up once in while and not riding it but just running it in the garage. You get condensation buildup because the oil doesnt get hot enough long enough to cook off the moisture. Its better not to start your bike at all if you dont plan on riding it for at least 30 minutes. Keep the battery charged and stabil in the fuel and when you do get ready to ride its ready for you. I used to be of the mind that if I started the bike up in the winter and warm it up I was helping it. After pulling the clutch apart because it finaly stuck so bad I couldnt break it loose I discovered that all the steel plates were rusted. It then dawned on me what had happened. If you dont start the engine you wont generate the condensation to begin with.
              I have had a small amount of moisture like this. Jusyt changed oil, followed above advice except no stabil & more riding, No further problem.
              I checked my final drive and found it filled past full to overflowing with milky looking oil. Any one else ever get this? It sure seemed like more than a little condensation.
              I was baffeled and incredulous. Could it have something to do with the heavy rain i rode in? Maybe several river crossings with no bridges, low water fords. Drain & change, no problem so far.
              Brent in GA
                Too much humidity down there Brent!...............You ride and it all gets hot, then as it cools the moisture is drawn in..............
                • Brent
                  • 959
                  Humidity... Yes. I have been leaving a light bulb on in the garage just to warm and dry the air.
                  Sounds like I should ride in Colorado more.
                  Thanks for great Idea.
                  Brent in Ga
                  Brent in GA
                    Riding in Colo...............good idea!................Sunny, 50degrees,..........but a little humid at 37percent
