Master Cylinder Covers?
  • MAXIMAN
    • Jan 2005
    • 1817
    Anyone have a source for replacement covers for the front MC?
    Cg
    Cody,
    Do you need one, or do you want a "new" one?
      Re: Master Cylinder Covers?
      Who was going to try producing aluminum ones???
      Cg
      • MAXIMAN
        • Jan 2005
        • 1817
        Ray
        Either way.
          I have an old standard MC. I can check it Tuesday.
          Ray
          • randy
            • Dec 2003
            • 4521
            Cody,
            If you can use a standard M/C, I have an NOS cover and bowl. PM me.
            • MAXIMAN
              • Jan 2005
              • 1817
              I'm not sure if the standards are the same size.
              I went to add brake fluid yesterday and the #%&$ screw twisted off. Had to drill it out and use and screw remover.
              When I drilled it I got into the countersink area of the cover where the screw seat.
              It still seals up but I'm afraid the metal may be so thin it might pull through over time and I don't need that on one of those 5000 mile road trips.
              Let's check around and see if a standard will work on my XJ M/C. If not I'm sure I can find a aftermarket replacement somewhere.
              • 0011mixam
                • Jan 2006
                • 42
                • Winnipeg, Manitoba, Canada
                Cody:
                Bike Bandit lists the cover for the XJ front master cylinder. Their P/N is 48197-001 and it's listed for $13.28. No way to tell if they have stock.
                Perry
                '82 XJ1100 (Second Childhood)
                Frame-up Restoration
                As Original as I Could Keep It
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  covers
                  I think the covers are the same. I know the reservoir and o-rings are diff. STD vs. Special. the special also slants more.... 2cntz
                  MDRNF
                  79F.....Not Stock
                  • HobbyMan
                    MeatHead Idiot "GURU"
                    • 1801
                    • Colleyville, TX
                    IS there a place to get complete reservoirs? Mine are starting to "warp" out and they look "cracked"
                    Acta Non Verba
                      I just today reconditioned a reservior from my Special. I clamped it in a vise, with cloth on the jaws, then took a file and started on the sides. The crumbly, flaky stuff came right off. The opaque, white plastic came back somewhat. I then sanded it with some 320 emory cloth, and it looks great. The depressions on the side for checking the fluid level, was kinda hard. I used a small pocket screwdriver, and scraped what I could from the depression, and started working a piece of sandpaper down in there. Sanding removed the lettering, but after much patience, it looks very good. I have a source for new O rings that seal the reservior to the master cylinder casting, so I replaced that also.
                      • Lamric
                        XStremely XSive(Deceased)
                        • 410
                        • Kenley, Surrey, England
                        eBay bargain ?
                        300075442409
                        Just found this, badly described, but Nissin made the original ones. Starting at $50, may fit a standard. The top looks like it would fit a special.
                        If you are especially desperate it may be worth a bid
                        Brian
                        XS1100 LG "Mr T", SG "ICBM" & FJ1200
                        Check out the XS Part Number Finder
                        Be not stingy in what costs nothing as courtesy, counsel and countenance.
                          Check out this thread on replacement reservoirs from a while back. Randy was managed to track down a supply of replacement units, and I bought up the remaining units from hin that he was not able to move. I've still got four of these units available to fit the front master cylinder on a standard only, not a special.
                          Read through to the end of the thread for a price, then PM me if you're interested.
                          • MAXIMAN
                            • Jan 2005
                            • 1817
                            I really don't need to replace the M/C. It's in perfect shape. Just the cover. That's what I slightly damaged during screw removal.
                            I was hoping to find a third party replcement cover...like I've seen for other bikes.
                            • OpFlash
                              • Feb 2005
                              • 197
                              • Chicago
                              Just bought a new front master cylinder cover from www.motogrid.com it was approx 12.50 brand new. It however does not have the same look as the original MC cover as it does not have the raised yamaha letters. it is oem yamaha cover that appears fits other bikes as well as the XJ but it does have a nice look. It has a smooth top with recessed yamaha letters in center and english and japanese writing on it.
