Rear Turn Signal Repair
  • corzen
    • Jan 2007
    • 15
    • Delta, B.C, Canada
    Need to repair my left rear turn signal. PO just has it siliconed into place. Right is fine but not sure what parts I need. Any help would be great. Here is what is looks like.
  • randy
    • Dec 2003
    • 4521
    Corzen,
    Take the right one apart to figure out which parts you need.
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      you are nissing a large rubber grommet bike bandit #9993-001
      Acta Non Verba
        Hey Corzen,
        The turn signal stalk looks like it might have gotten broken at the base? Partsnmore sells the stalks for cheap. BikeBandit wants 3 times as much, but they also have the rubber gasket.
        1 10M-83310-K0-00 FRONT FLASHER LIGHT ASS'Y 1 2
        2 256-84714-61-00 BULB (12V-27/8W) 1
        3 4H7-83312-00-00 LENS, FLASHER 1
        4 4H7-83313-00-00 GASKET, FLASHER LENS 1
        5 98501-03030-00 SCREW, PAN HEAD 2
        6 95702-12100-00 NUT, FLANGE 2
        7 10M-83325-00-00 BOLT, FLASHER STAY FITTING 2
        8 4X7-83328-00-00 STAY, FLASHER 2 2
        9 97301-06030-00 BOLT (97303-06030) 2
        10 95701-06100-00 NUT, FLANGE 2
        11 341-83321-01-00 DAMPER, FLASHER 1 2
        12 10M-83330-E0-00 REAR FLASHER LIGHT ASS'Y 1 1
        13 256-83311-70-00 BULB (12V-27W) 1
        14 4H7-83312-00-00 LENS, FLASHER 1
        15 4H7-83313-00-00 GASKET, FLASHER LENS 1
        16 98501-03030-00 SCREW, PAN HEAD 2
        17 10M-83340-E0-00 REAR FLASHER LIGHTASS'Y 1
        18 256-83311-70-00 BULB (12V-27W) 1
        19 4H7-83312-00-00 LENS, FLASHER 1
        20 4H7-83313-00-00 GASKET, FLASHER LENS 1
        21 98501-03030-00 SCREW, PAN HEAD 2
        22 90209-12222-00 WASHER 2
        23 90170-12292-00 NUT 2
        24 4X7-83325-00-00 BOLT, FLASHER STAY FITTING 2
        25 4X7-83328-00-00 STAY, FLASHER 2 2
        26 97301-06030-00 BOLT (97303-06030) 2
        27 95701-06100-00 NUT, FLANGE 2
        28 1E6-83321-00-00 DAMPER, FLASHER 1
        Partsnmore.com
        CHROME SIGNAL STEM
        Fits Front and Rear: XJ1100 (1982)
        $5.00US EA.
        Part#11-2166
        • The Lorax
          • Jun 2005
          • 1048
          • Riverside, OH
          There's also some kind oh eliptical baseon the end of the stalk. I think (feel free to correct me if I'm mistaken) it keeps the signal from turning and pointing down or up or forward etc. if you cant find a new replacement, try a boneyard, or ebay, or anyone you know that might have one, or get something aftermarket...you know whatever you want to do man....L8
          I am the Lorax, I speak for the Trees
          '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
          '79 XS1100 F R (IL Barrachino)
          '00 Suzuki Intruder 1400 (La Soccola)
          '77 KZ400s (La Putana)
          • andreashweiss
            • 951
            I will look in the garage tomorrow to see if I have a chrome stock for the signals.Certainly will have the rubber frame crommet.Send me a PM . I might have a complete signal assembly and the chrome piece that fits inside the rubber frame crommet. andreas
              Lorax, the XJ and XS Specials have a square shaped rubber grommet hole and outer shape, the square shaped stalk fits into it, and the rubber grommet aligns with the square hole in the frame which keeps it aligned. The XS650's were the ones that used the elliptical shaped bracket base and grommets with a positioning pin!
              • The Lorax
                • Jun 2005
                • 1048
                • Riverside, OH
                oh, ok, must be more hybrid inbred parts on mine...had no rear signals when I got it, bought some from a boneyard....I thought they fit in the holes a little funny...oh well, they blink, guess I'll chock that one up to experience.
