Driling My Discs
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    cobalt
    i used cobalt bits. and a press...
    MDRNF
    79F.....Not Stock
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      it appears to me the split point would not center into the centerpunch reference and walk, is this not true?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        • 7819
        A LIGHT pressure as you start will keep the bit on center. I used one bit for my rotors, and I did bolt together the two front rotors so they would be a mirror of each other.
        I also used a large plastic "planter dish" as a catch for the oil. it keeps the mess WAY down. I put some small bits of 1X4 wood under the rotors, and then kept the oil flowing as I drilled. It took about 1 hour per rotor.
        Ray
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          Ray
          diverray,
          did you drill the two rotors bolted together? is that the reason to bolt?
          and was the dish between the stand and the woods?
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
            • 7819
            Yes, that was the reason for bolting them together. I was able to drill through two disks in just a little more time than one would take. It is harder getting the bit aligned and started than drilling.
            I bought a large diameter, 4" deep plastic "pan", put the wood in, and put the rotors on the wood. I turned the complete assembly, not just the rotor, as I started a new hole. I did keep the cutting fluid flowing, with a "squirt" bottle to hold it. I mostly let it dribble down the bit as it turned.
            Ray
              Mason,
              The tip of the bit is complete, it's just split down the edge of the cutting surface. Here's a photo:
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                Ray
                what happen to your clamping the unit down? none?
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • Dennyz
                  • 1151
                  • Olympia, Washington
                  My pattern
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    Re: My pattern
                    Originally posted by Dennyz
                    no offense to anyone else but i like your pattern the best, slick
                    can you send me a pattern?
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • pggg
                      • 1609
                      • NZ
                      Again, DON'T do what I did, the holes are supposed to stop these streaks on your discs - only if the pattern of holes cover all the swept surface so drill em' different on each line
                      • Ken Talbot
                        • 4251
                        • Revelstoke, BC
                        Actually, a split point centers much better into a centrepunch mark. For illustration, here's a shot of a freshly ground 135 degree standard point. Notice the fairly wide, flat section in the middle of the bit. As you start drilling, this section does not cut at all. You actually force the bit into the metal a small ways so the flutes can start digging. This is also part of the reason why a standard grind bit wanders so much.
                        Next, here's a shot of the same 135 degree bit, but this time with the point split. Notice the gap right in the middle where the wide, flat saddle has been ground away. Now, there are two fine, sharp points ready to start removing metal as soon as the bit contacts the workpiece. Those two points are close enough they both sit nicely down into a centrepunch mark.
                        Ken Talbot
                          Hey Ken,
                          I stand corrected, cause your photo clearly shows the split on the actual tip, not halfway down the side of the cutting surface like the one I showed!? I guess what I found was actually Split "Tip", but not Split POINT?? I've got some bits where theres a small groove cut into the cutting edge about halfway down from the tip!
                          Learn something new every day on Channel 11!
                          • Dennyz
                            • 1151
                            The holes on my rotors overlap to prevent streaking.
                            DZ
                            Vyger, 'F'
                            "The Special", 'SF'
                            '08 FJR1300
                            • Dennyz
                              • 1151
                              I don't have a drawing of the pattern to send. The pattern is pretty easy to set up, however.
                              If you notice, the top hole lines up with the previous set's bottom hole. This makes it easy to create a template that locates on the rotor's center hole and only has locations of one set of holes.
                              I center punched a set of holes, rotate the template (indexing with the last (bottom) hole and punch another set.
                              To make sure the right side and left side would match. I started from a rotor mounting bolt hole.
                              DZ
                              Vyger, 'F'
                              "The Special", 'SF'
                              '08 FJR1300
                                • 7819
                                Mason,
                                I (gasp) held the disk down by hand!! And no, it wasn't that hard, There is a LOT of mass, so it didn;t try to spin very much.
                                Ray
