Driling My Discs
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    Mason,
    I (gasp) held the disk down by hand!! And no, it wasn't that hard, There is a LOT of mass, so it didn;t try to spin very much.
    Ray
    you are pretty big, you have met me, do you think it's dangerous for me to hold it down?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • mason79
      • Mar 2006
      • 1351
      • los angeles, ca
      Originally posted by Dennyz
      I don't have a drawing of the pattern to send. The pattern is pretty easy to set up, however.
      If you notice, the top hole lines up with the previous set's bottom hole. This makes it easy to create a template that locates on the rotor's center hole and only has locations of one set of holes.
      I center punched a set of holes, rotate the template (indexing with the last (bottom) hole and punch another set.
      To make sure the right side and left side would match. I started from a rotor mounting bolt hole.
      ok then what was the radius of your sweep,
      if i measure the straight line distance from cl of the first hole to cl of the last hole of a set of holes, i can place this measurment on the sweep, and space out the holes equally.
      you have 12 sets of hole per discs right?
      then i would put a clock pattern on the disc with straight lines radiating from the rotor's center, starting the first set of holes from a rotor bolt hole.
      then i'll use this pattern and gap adjacent lines from bottom of one to the top of the next line; ccw for the right rotors and cw for the left rotor.
      is the rear rotor the same dia and the fronts?
      do you think i am on track or off track? thanks
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • Dennyz
        • 1151
        • Olympia, Washington
        You are right on track.
        There are 12 sets of holes. The top and bottom holes are on the hour (every 30 degrees). The rest of the holes are on the second (every 6 degees).
        The top hole is centered on the top wear line and the bottom hole is centered on the lower wear line of the rotor. The remaining holes are centered between the top and bottom holes and where the 6 degree angle intersects. This is what creates the arc.
        I drew the lines in with a pencil to make the visible to the camera. You are looking at the template as it would apply to the right side.
        Remember to start the pattern from one of the rotor mounting hole at 12 o'clock so the right and left side will match. You will notice that one of the mounting holes is centered on a rotor spoke. That is where I started.
        Yes, the rear rotor is just like the right front rotor.
        Happy drilling!
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
        • mason79
          • Mar 2006
          • 1351
          • los angeles, ca
          #34
          Originally posted by Ken Talbot
          Mason, try the pdf template files on this link I just checked it out and did not have any trouble.
          As you scan the article, you'll see I had no trouble drilling the rotors with plain, garden-variety cheap drill bits. Mind you, I did use a fairly decent sharpener to change the bits to a better split point, and ket the bits sharp. The the rotor material is not difficult to drill if you use a low feed speed, cutting fluid, and a freshly sharpened split-point drill bit.
          hey ken,
          do all drill sharpeners have the ability to creat a split tip on bits?
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            #35
            Drill sharpeners...
            Only sharpeners that do 135 degree split point are professional models, way too expensive. However with the years of experience I have doing that I can do it on a bench grinder. Get some old drills and practice, you can probably do it too. If you buy them that way and don't wear them out too much you can put a new edge on them pretty easily.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
              #36
              Originally posted by mason79
              hey ken,
              I'm only familiar with the Drill Doctor units. Their models 500 (1/2" max) and 750 (3/4" max) will both do split points. I've got a model 750 on its way for my BL and it cost US$119 plus shipping. The lowest price I've seen online for a model 500 is about US$88. They also have a model 350 that can be had for about US$59, but it will not do split points.
              • mason79
                • Mar 2006
                • 1351
                • los angeles, ca
                #37
                since this will be my only drilling project, how much cutting fluid will i actually require? 8oz? 4oz?
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                  #38
                  Probably not even an ounce to drill a set of three rotors. Just buy the smallest bottle you can find. The 4 ounce bottle I bought still has lots left.
                  • mason79
                    • Mar 2006
                    • 1351
                    • los angeles, ca
                    #39
                    your the man!
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • mason79
                      • Mar 2006
                      • 1351
                      • los angeles, ca
                      #40
                      there are different sizes of center punches i have learned which should i use?
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                        #41
                        I use a 1/8" punch for just about everything I do, but that's really because the next biggest size in my toolbox is dull. Like a lot of tools, you just want to be sure your punch is sharp enough so it doesn't bounce or skate all over the place when you give it a whack. You don't need to keep hitting it till it has produced a 1/8" crater either. A crater between 1/32" and 1/16" will be plenty if you are using split point bits.
                        • mason79
                          • Mar 2006
                          • 1351
                          • los angeles, ca
                          #42
                          thanks, should i bother the check the thickness of the disc rotor and account for the scoring, or just drill and pray? or play rather.
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                          • planedick
                            • Mar 2005
                            • 2068
                            #43
                            Scoring?
                            I wonder why you would put so much effort into drilling discs that are scored. If they are badly scored they may be no good anyway unless there is enough thickness to clean up and still be thick enough.
                            Drilled airbox
                            Tkat fork brace
                            Hardly mufflers
                            late model carbs
                            Newer style fuses
                            Oil pressure guage
                            • mason79
                              • Mar 2006
                              • 1351
                              • los angeles, ca
                              #44
                              you know that i am bored, and i am not buying new ones, they stop fine, i'm doing this mostly for show, i will ride 5k miles a year, so i'll look good for 5 ....maybe....
                              History
                              85 Yamaha FJ 1100
                              79 yamaha xs1100f
                              03 honda cbr 600 f4
                              91 yamaha fzr 600
                              84 yamaha fj 1100
                              82 yamaha seca 750
                              87 yamaha fazer
                              86 yamaha maxim x
                              82 yamaha vision
                              78 yamaha rd 400
                              • mason79
                                • Mar 2006
                                • 1351
                                • los angeles, ca
                                #45
                                2 down 1 to go
                                thanks guys again for the xs university.
                                drill press 39.95 plus tax
                                cobolt drillbit 2.50 ebay
                                center punch 4 bucks
                                cutting fluid 4 bucks
                                protractor 4 bucks
                                countersink 2.00 harbour freight
                                History
                                85 Yamaha FJ 1100
                                79 yamaha xs1100f
                                03 honda cbr 600 f4
                                91 yamaha fzr 600
                                84 yamaha fj 1100
                                82 yamaha seca 750
                                87 yamaha fazer
                                86 yamaha maxim x
                                82 yamaha vision
                                78 yamaha rd 400
