Driling My Discs
  • Driling My Discs
    I went to the mods page and the pdf and pictures won't load,help
    can i drill without chamfering the holes and if i have to chamfer, what size do i chamfer it with and is it just to knock any burrs off?
    what is the recommended size of the holes max size?
    what are the benefits of drilling other that it looks bi-oching
    if i do it i promise to upload some pictures
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Drilling the rotors will aid in cooling and help disperse water. I put the later slotted rotors on my 79F. Good luck!
      Hard
      You will find that the rotors are VERY hard and even using carbide drills you will have to have lots of them. The steel is nearly as hard as a carbide drill. Best way is to take them to a machine shop where they have a sinker type EDM. It will cost less and get much better results.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
        I drilled mine with a HHS cobalt drill, not the nitride coated one, and I only had to sharpen after each disk. I used the pattern I found on this site. You need a drill press, preferably with auto feed, run a slow speed, and use thread cutting compound. I am thinking I could have drilled all three disks without sharpening, but I played safe. Stopped all the squealing probs I had on both ends. Oh, drill size 1/4" and I used a countersink to deburr. You could use a 5/16 to deburr, but watch for chatter. Only necessary to remove the burr
        put something smooooth betwen your legs, XS eleven
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        79 XS 650S (gone to MC heaven)
        76 CB 750 (gone to MC heaven)
        rover has spoken
          I drilled this using 4 different size drills
          and only 1 of each
          trick is to use a drill press and use oil on the drill
          http://home.securespeed.us/~xswilly/
          79F Parts
          80G Parts
          75 DT 400B enduro
            and only 1 of each
            nice, heck i think i'm having an lsd flashback looking at those...
            i want to do 12 columns will that weaken the disc too much?
            and can anyone email me that pdf, the page's links are all dead as far a s the pictures and files, help!!
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
              Mason, try the pdf template files on this link I just checked it out and did not have any trouble.
              As you scan the article, you'll see I had no trouble drilling the rotors with plain, garden-variety cheap drill bits. Mind you, I did use a fairly decent sharpener to change the bits to a better split point, and ket the bits sharp. The the rotor material is not difficult to drill if you use a low feed speed, cutting fluid, and a freshly sharpened split-point drill bit.
              Ken Talbot
                does the 5/16 counter sink bit need to be hhs cobalt as well?
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                  As you scan the article, you'll see I had no trouble drilling the rotors with plain, garden-variety cheap drill bits. Mind you, I did use a faialy decent sharpener to change the bits to a better split point, and ket the bits sharp. The the rotor material is not difficult to drill if you use a low feed speed, cutting fluid, and a freshly sharpened split-point drill bit.
                  yes ken , can i buy a cheap drill press, i see them going on ebay for 19.99, crazy man, or harbor freight, when i'm done it's done, right?
                  split point you mean angle? duh...
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                    Split point
                    Split point is a type of drill sharpening that is 135 degree angle and an offset point that helps keep the drill from wandering when you start and is a little more aggressive in cutting and feed rate. I would be real interested in hearing how this went when you get done.
                    Drilled airbox
                    Tkat fork brace
                    Hardly mufflers
                    late model carbs
                    Newer style fuses
                    Oil pressure guage
                      Re: Split point
                      i'm coming over to use your drill press dude...
                      and no complaining
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                        Don't do what I did and 'burn' the disc with impatience coz the drill holes turn as hard as hell and get harder and harder with each attempt.
                        • #13
                          thanks everyone again roger wilco over... roger wilco over
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                          • #14
                            The drillpress I used for my rotors cost me a bit more than 19.99, but is still just one of the no-name brand, cheapo types that you can buy all over the place. I've been using it for years without any trouble. It's biggest drawback is the lack of the really slow speeds that you would want for large holes in steel, but it's slowest speed worked just great for the 1/4" diameter holes I put on my rotors. The counter-sink I used was also a garden-variety HSS unit.
                            pggg is right on when he advised not to get impatient and trying to drill too fast with too much pressure. With just the right feed speed, you get beautiful, long curly spirals all the way through each hole, and it feels like you're cutting through butter.
                            Ken Talbot
                            • #15
                              When I drilled my rotors I used a simple bench top drill press I had from Home Depot for $99.00. The bit, lubrication and patience is the key.
                              I have two size holes, 1/4" and 5/16". I used Norseman cobalt bits. Bits you get at places like Home Depot or a hardware store will usually not last. You have to get professional bits from tool dealers. I bought three of each for the job (one for each rotor) but did all the work with one bit. The very best way to make the hole is to use steady pressure, low RPM (600-800) and constant oiling while the bit is cutting. It is a mess but oiling the bit constantly makes it cut through like butter. If your bit is cutting correctly you should be getting long spirals of metal. Then I used a 5/8" bit to slightly chamfer each hole. Then clean up very well with brake parts cleaner.
                              The 'hole' deal only took a few hours to do.
                              Mike Giroir
                              79 XS-1100 Special
