Another carb question...
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    I know that the float height effects mixture, but I'm beginning to think it only effects the idle mix except when it's so low it runs out on the top end. After I got the cam timing set I was experiencing VERY lean conditions. Syncronizing and raising the float made the idle OK, but excelleration in the bottom end was misfiring and crapping on the top end and VERY lean. Lowered the clip on the needles and top end and midrange is OK, but now idle is WAY too rich. It appears that needle position effects idle mix too. I wonder if lowering the float will help lean out the idle mix?
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    I'd go back to your original clip setting and go up a step or two(one step=2.5) in the mains. You want a happy medium of mileage and performance. My 81 Venturer loved 115mains for response and performance gains, but mileage suffered and plugs had a 'dusting' of black, so running 110's which is stock for sea level(go figure at 5,000ft.), but float levels are lowered at 25mm. Don't know what year you have but it's all realative to cause and effect, same difference.
    • HobbyMan
      MeatHead Idiot "GURU"
      • Jul 2006
      • 1801
      • Colleyville, TX
      I would do what he said. Set float height as per manual. Adjust mixture by the jets
      Acta Non Verba
      • planedick
        • Mar 2005
        • 2068
        Why????
        I don't understand what could make it so far from stock set-up. Stock airbox & filter, stock pipes and mufflers??????? My question was, "Does float height effect only the idle mix, or does it effect both idle and high speed mixture?"
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          Re: Why????
          try this richard
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • mro
            • Oct 2005
            • 4276
            • Hayward, California
            Sounds like your trying to adjust the carbs to solve a problem that could be something else.
            All cylinders firing??
            (can do the sizzle test on headers to see if all firing near the same)
            Have you checked to be sure there are no vacuum leaks?
            Carb boots sealing good on head, rubber seals good on throttle shaft, diaphragms, vacuum lines and the two plugs good? Vents clear?
            78E float height 24.7 to 26.7 mm (25mm works)
            When I get to a point of frustration, generally start over with the basics. Could be something that was taken for granted as good is not.
            mro
            btw, read a post last year where a guy had lost a socket, which had wound up in the inlet for filter box. Kinda like having a full time choke on
            • planedick
              • Mar 2005
              • 2068
              Float height
              I have an infrared heat gun so I can check the pipes at idle for heat eveness. I think it's better than the water splash. New spark plugs. One thing for sure, I have become an expert at getting those carbs off and on. Changing needle clip positions is really easy without taking the carbs off.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              • planedick
                • Mar 2005
                • 2068
                Thanks
                A thank you to Mason, very good information. Looks like you have spent more time doing searches than I have. Interesting that page has no information about who or where they are. Sure wish I had a dyno here, putting the tank and seat and all the other stuff on just to do a quick test is time consuming.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
