Strange Diagram
  • Filter
  • Strange Diagram
    Pulled the side cover from my 78 E today and noticed two diagrams in there. One was covering the petcock hose route but the other had me stumped. The writing has worn off a bit so couldn't read it all.
    Something about wire.
    Had a diagram showing the bike from the back showing a wire going from the hook on the right of the swingarm by the axle, up through the two hooks under the seat and back down to the bottom of the left hand shock.
    Anyone enlighten me as to the purpose of this wire and the missing writing on the diagram?????
    1981 XJ550RH
    1978 XS1100E The Wildebeast
    1978 XS1100F X Streem
    1980 XS1100G (with an E motor)(parts bike)
    Jet/Mod Calculator
    Speed/Gearing Calculator
  • #2
    Probably
    Apparently, there is some class of cable device to suspend the rear suspension when changing the tire(tyre).
    This allows the axle to clear the exhaust during removal. My understanding is that this only necessary on the STD model. My guess is that it is attached while the suspension is compressed, and then the center stand is deployed.
    XS1100SF
    XS1100F
    • #3
      thats correct
      there is a cable and a pry bar
      you connect the cable , use the pry bar to lift the rear axle to clear the exhaust
      only on standards
      http://home.securespeed.us/~xswilly/
      78E main ride, since birth the "good"
      78E Parts, the "bad" fixing up now
      78E Parts the "ugly" maybe next year
      79F Parts
      80G Parts
      75 DT 400B enduro
      • #4
        Thanx
        Damn, now that makes perfect sense.
        Yes a standard, but not required with my 4 into 1 clearing the pipes anyway.
        Here's my brain looking at the diagram thinking this is some sort of lowering device for the drags.
        1981 XJ550RH
        Jet/Mod Calculator
        • #5
          And, it was only necessary/handy on the early standards with the longer mufflers that went past the axle. On later standards like Tsunami , the mufflers are shorter so they end before the axle.
          • #6
            I have the cable device. It is supposed to be stored in the onboard tool box? Just wondering. And yes to reconfirm, that is the diagram.
            Acta Non Verba
            • #7
              There is, or is supposed to be, a box like compartment inside the left side cover for storage. I think that label is on the outside of it.
              Steve
              73 Yamaha DT3 - DirtyHairy
              CZ 400 MX'er
              68 Ducati Scrambler
              RC Planes and Helis
              • #8
                yeah, Ive got my tools in there but is the cable supposed to go with it. It is a tight fit
                Acta Non Verba
                • #9
                  cable trick
                  I got the cable with the Pathfinder and when the rear went flat I discovered how nice it really is since I still have the stock pipes. Works really cool.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • #10
                    I just put a stock exhaust back on my 79F. Does anybody have a cable they want to sell? I don't think I will be bringing the 2x4s, that I have my rear tire propped up with, on any road trips. Thanks, PN.
