A fork brace improves handling by...
Finish this sentence...
Hi...my name is Mike, and I'm a lane-splitter.
'80 XS1100SG (mine)
'87 CMX450C Rebel (daughter's first bike)Tags: None -
...... causing your fork legs to move up and down together instead of (slightly independantly). The independant movement causes wheel deflection side to side. The fork brace helps to eliminate this.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
......stiffens up the front end, like our front fender does, but doesn't block water or dirt.
Why is a brace better than the big metal fender that we have up front?
Ed79 XS1100SF
78 YZ400E
81 SR500
79 RM250
77 YZ400D
05 RM250
78 CR 250 Husky w/TT500 motorComment
Ed
T.C.T. C. Gresham
The forces exerted on the big metal fender are huge, and they will flex. A fork brace keeps everthing in line and working together. I installed one years ago and all I can say is it works. Between a fork brace and new fork springs (which I don,t have yet) handling AND straight line stabilty at sublight speeds is vastly improved. My high speed weave thru long sweepers was noticeably absent after the brace install, (or should I say the weave did not show up till much higher speeds). This springs project (no pun) is new fork springs and rear shocks. Then I am really gonna hunt me some sport bikes on the weekends.When a 10 isn't enough, get a 11. 80g HardbaggerComment
a lot
JimSeamus Ó hUrmholtaigh
Niimi Moozhwaagan
and SOXS
2008 Nomad "Deja Buick'Comment
always want what you can't have
Originally posted by Ken Talbot
... stiffening your front end..."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
Diamond Cutter
Like tonight, a little blast above 110 mph, cut over to other lane to pass, hit minor pot holes and front shimmy some.
Gets your attention/adrenalin going.
My "hot rod XS" has both a tube and thrat? brace as well as after market progressive forks and kona rears. Rock steady 130+...
mroComment
Re: Diamond Cutter
mro
i want koni's"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
