Finish this sentence...
  • Finish this sentence...
    A fork brace improves handling by...
    Hi...my name is Mike, and I'm a lane-splitter.
    '80 XS1100SG (mine)
    '87 CMX450C Rebel (daughter's first bike)
    hmmm
    keeping your fork tubes straight under heavy load?
    MDRNF
    79F.....Not Stock
      Oh, great, now we're having pop quizzes?
      Ok,
      - What xschop said:
      Minimizing fork flex.
      Oh, yeah, and they look good, too!
        braggin
        I bought 2 pair for 20 bucks and sold 1 pair for 25, so if my math is correct, Did I get mine for free?
        MDRNF
        79F.....Not Stock
          ... stiffening your front end...
          Ken Talbot
            ...... causing your fork legs to move up and down together instead of (slightly independantly). The independant movement causes wheel deflection side to side. The fork brace helps to eliminate this.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
              ......stiffens up the front end, like our front fender does, but doesn't block water or dirt.
              Why is a brace better than the big metal fender that we have up front?
              Ed
              79 XS1100SF
              78 YZ400E
              81 SR500
              79 RM250
              77 YZ400D
              05 RM250
              78 CR 250 Husky w/TT500 motor
                Ed
                Edgo, that front fender is much thinner and does flex quite a bit. The XJ's fender was made much thicker and does work like a FB, but the XS's are too thin to really provide much antiflex action without the extra FB!
                  The forces exerted on the big metal fender are huge, and they will flex. A fork brace keeps everthing in line and working together. I installed one years ago and all I can say is it works. Between a fork brace and new fork springs (which I don,t have yet) handling AND straight line stabilty at sublight speeds is vastly improved. My high speed weave thru long sweepers was noticeably absent after the brace install, (or should I say the weave did not show up till much higher speeds). This springs project (no pun) is new fork springs and rear shocks. Then I am really gonna hunt me some sport bikes on the weekends.
                    a lot
                    Seamus Ó hUrmholtaigh
                    Niimi Moozhwaagan
                    and SOXS
                    2008 Nomad "Deja Buick'
                      always want what you can't have
                      why would anyone that rides an eleven want a stiffer front end?, oh i guess, you want it to behave while pointing it up the alley.
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                        Ken Talbot
                        • #13
                          Diamond Cutter
                          My 80G has but the old tube tybe brace.
                          Like tonight, a little blast above 110 mph, cut over to other lane to pass, hit minor pot holes and front shimmy some.
                          Gets your attention/adrenalin going.
                          My "hot rod XS" has both a tube and thrat? brace as well as after market progressive forks and kona rears. Rock steady 130+...
                          mro
                          • #14
                            Re: Diamond Cutter
                            mro
                            i'm jealous, my carbs are off and bigger holes were put in awaiting indy's and a new mac 4 to 1, then i go test,
                            i want koni's
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
                            • #15
                              i want koni's
                              Might have an extra pair.
                              Hope next week to post all extra parts I don't need for sale.
                              mro
                              btw
                              Plan to replace the return throttle cable tomorrow on the hot rod.
                              Then go for a ride.........
