TC's oil adapter removal?
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    Hi all,
    I'm in the process of splitting my cases to fix my starter clutch and replace a couple crank seals and have found that I need to remove my oil filter adapter because a bolt or two is under it. Anyone have any idea how to properly remove the adapter without damaging it?
  • John
    • 5117
    Remove the large threaded tube that holds it to the engine?
      Getting Strapped for a solution!
      Hey Snow,
      Get a strap wrench, one of those rubber type, and use it to unscrew the main plate from the pipe! Depending on how well secured the center mounting pipe is, either the plate will unscrew off of the pipe, or it will unscrew the pipe and plate in one piece!?
      That would actually be the worst scenario, cause it can be more difficult to remove the pipe from the plate without damaging the pipe! And securing the plate/pipe already assembled combo "may" not provide as good of a secure fitting when trying to put it back on, due to the pipe possibly NOT bottoming out in the filter bolt hole in the case?? However, using stud strength locktite should allow it to be resecured with confidence!
      If the pipe stays in the housing, that's okay, it shouldn't get in your way to loosen the case bolts, etc.!
      But, if you FUBAR the pipe section, I can get you another one for a nominal fee!
      • MAXIMAN
        • Jan 2005
        • 1817
        • As far from the government as humanly possible.
        Jus use astrap wrench like he said. Mine broke loose leaving the threaded pipe in the block.
        Of course mine has an "O"-ring groove cut in it so it broke easy at the plate face.
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Still no joy - I think I may have to put a couple nuts on the pipe to spin it all off...this sucker isn't budging...maybe I should try some liquid canned air to freeze the goop...
          • 81xsproject
            • 3185
            • Fortuna, CA
            I would try heating it before freezing.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              What would you use for heat? Some type of torch? This thing is really stuck on!
              • xssiveone
                • 766
                • Windsor,Ontario,Canada
                I think I'd be using a heat gun before I tried a torch. I think a torch would be too aggressive for this.
                Brian
                remembering the same thing!
                • Snow
                  • Oct 2002
                  • 1041
                  • Tallahassee, FL
                  We finally got a Harbor Freight in town, do you think this might work? I've been meaning to get a heat gun for another project anyway...
                  http://www.harborfreight.com/cpi/cta...emnumber=35776
                  • Ken Talbot
                    • 4251
                    • Revelstoke, BC
                    For ten bucks, you can't go wrong.
                    Ken Talbot
                      Snow,
                      Dang, sorry you're having so much trouble getting that thing off! With the heat gun, I would recommend the lower setting. The melting point of T6061 aluminum is around 600C, which is around 1100 F! You don't want to get it too soft and have it distort or warp!
                      IF the smaller strap wrenches aren't doing it, you might have to try a larger chain pipe strap type wrench to get a better grip and provide more leverage!?
                      If all else fails, and you have to cut it off, , I'll be happy to send you another one at COST! Hope you're successful!
                        How did you finally get the SOFA OFF?
                        Hey Snow,
                        I know you're struggling with your alt rotor, but you never posted about getting the SOFA plate off! What did you have to do to get it off? We know you did cause you were able to split your cases to fix your starter clutch!
                        BTW, what type/brand of sealant did you use to put it on with?
                        • Snow
                          • Oct 2002
                          • 1041
                          • Tallahassee, FL
                          Oh, yeah, sorry about that! I finally went King Kong on it and use a pair of Craftsman vicegrips to spin the tube, which was stuck to the adapter plate - it all came off in one piece. I really do think I may have used loctite on the sucker as I was afraid it might come loose. After all I did, I think I managed to destroy both my plate (don't ask) and the tube.
                          I think I used Permatex copper or red - the stuff looked kinda orange.
