special vs. standard muffler brackets
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    it may have been asked before but i can't find it.
    question is, will a special foot pegs bracket bolt right up to a standard frame? that way i can sweep the slip on's up instead of straight back, when the time comes... and thanks for the help as always
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Nope. They won't swap. The right side will not bolt up because of the location of the rear brake pivot hole in relationship to the front footpegs/engine mount hole. I tried to fit the brackets from a 78E onto my 80SG and that is what I found.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      i'm not giving up yet, john, thanks for the bad news, so i guess the left will fit right?
      and your saying the measurment from the rear brake lever pivot centerline, to front peg mounting bolt center line is different than the standards,
      or are you saying that all the holes are in the wrong place , can i leave a bolt out, cause the specail bracket looks like there is an extra bolt right behind the pivot hole and the standard does not.
      how about a little butchering? any chance?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        It is the distance between the two holes mentioned that is off, and there is no way to make it work, short of making a new bracket with the correct dimensions, on a CNC machine. I tried the right side first, and when it didn't fit, I never tried the left side.
