xs eleven special shifter
+ More Options
Posts
    Let's try it again:
    Originally posted by Ken Talbot
    Here's an extact from a note with a few photos that I forwarded
    some time ago when another Xsive was having trouble with his
    shifter. This should give you an idea of how the shifter works, and why yours doesn't......
    First, here's an overview shot of what is inside the shifter cover. Note
    the shift shaft assembly on the right - this where the shift pedal attaches....
    Under the shift shaft assembly is a torsion spring....
    The torsion spring returns the shift shaft assembly to a central position....
    Here's what it looks like when you are shifting up....
    and when you are shifting down....
    You can see that gravity would help return the shift shaft assembly to the centre position if the spring was broken, but but it would not help when shifting down.
    • Incubus
      • 1003
      • Austin TX
      Ken, is that set of pictures in tech tips somewhere? If it's not, it should be. That's about the clearest photographic explanation of a constant mesh transmission shifter as I've seen.
      Patrick
      XS11F (Incubus, daily rider)
      1969 Yamaha DT1B
        Thanks, Patrick. You're probably right that this should be done up as a proper tech tip to list in the repairs/transmission section. The only reason it hasn't been is the length of my list of 'my projects'. Of course, there's also the length of SWMBO's list of 'my projects'. It will be done.....
        • Incubus
          • 1003
          • Austin TX
          Perhaps, for the time being, this thread could be linked from tech tips under a heading like "Shifter- Pictures and discussion."
          Just a thought. You could, of course, edit out the discussion about making it a thread. Except that part about how great I think it is.
          Patrick
          1969 Yamaha DT1B
            Tech Tip Added!
            Poof, It's DONE!
            Shift Lever Return Spring Pictorial tip
            • Incubus
              • 1003
              • Austin TX
              Perfect
              Cool, T.C. That quality of graphic explanation shouldn't get lost in the bowels of the archives, left to random chance.....
              Patrick
              1969 Yamaha DT1B
              • thewright1
                • Aug 2009
                • 198
                • Orange County CA
                This post is awesome, it's just what I was looking for. Do you guys use a gasket for the crankcase? I heard that some silicon will do the trick, I just wanted to ask the pros.
                1980 XS1100SG
                In the process of making her look pretty!
                P.S., TomRodgers has the best avatar icon ever!
                  I have used paper gasket material for the shift fork cover a couple times and it always leaked on me. I always use RTV for that one now. Many folks tal about "The Right Stuff" being the bomb shnizzle for gasket material.
                  • thewright1
                    • Aug 2009
                    • 198
                    • Orange County CA
                    Awesome, and you haven't experienced any leaking with RTV?
                    1980 XS1100SG
                      Not a drop with the black RTV so far.
                      • thewright1
                        • Aug 2009
                        • 198
                        • Orange County CA
                        Ok, that is good to hear. That's perfect.
                        1980 XS1100SG
