popping out of gear
  • tjfisher30
    • 79
    • orlando fl
    popping out of gear
    ok just riding around at slow speeds in second gear when it pops out of gear back into nuetral ? any ideas what do i need to do
    80 xs11 sg
    tjfisher30,
    Yes, read the "Tech Tip" from the main page, Transmission, 2nd gear fix.
    The job sounds like a lot, but can be done without pulling the engine or splitting cases. I did mine, first time, in two days. I also drained everything and had the bike upside down on a low stand. That DID make it easy to work on.
    Plan on doing a dremmel fix on first and second gear, just to be safe.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      Re: popping out of gear
      yeah mine does that too, not when i haul butt, so i just pop it in and move on,
      i might be a lame rider, cause, almost everytime i ride i get a false 4 to 5 false neutral and i can never get it back in up or down without grinding the bejesus outof it
      to me this is a worse offender that crusing gingerly in second and it slipping out, but i'm sure she wouldn't like it tho.
      any more comments on this?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        Your false neutral problem sounds more like it might be from a weak or broken shifter return spring, or mis-alignment in the shifter assembly. Have a look at this thread to see if this might be your problem.
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          i had the darn thing out a few time trying to stop the neutral switch's leak and the alignment and spring appears quite good, i think i don't pay enough attention when shifting and half fast shifting that causes the falses, not diliberate enough as i read elsewhere here...thanks, any rationlization not to do mechanical work, i just wanna ride damnit.
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
