Hello,
I have a 1979 XS11 Special. It has the Kerker 4-into-1 and a drilled airbox. It sat for about a year before I bought it. I drained the gas and ran some sea foam thru it. It would pull hard on top end but at part-throttle it had a backfire. I took the carbs off and dipped them then rejetted with Mikuni 145 mains and 45 pilots per a chart I found on this site.
NOW....with everything back together it starts right up, and will rev freely when it's sitting still but when I ride it, as soon as I get on the throttle it starts sputtering and cutting out. I bypassed the octopus and ran inline filters. Thought it might have been an air bubble in them so I plumbed it directly from the petcocks to the carbs, still the same thing. I set the floats according to the Clymers manual. Can a float(s) out of adjustment cause this problem.
P.s. I've got good compression and spark on all four cylinders.
Please help!
Thanks,
Scott
Please help!
Thanks,
Scott
so I'm just throwing out some ideas.
