Polyurethane mounts
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Polyurethane mounts
    Who would be interested in a set (6) xs1100 mounts from polyurethane. If I get enough interest I will place an order for the exact tolerances instead of cutting down and drilling 28mm poly rods.....chop
    MDRNF
    79F.....Not Stock
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    would they buzz the bike, what are the benefits?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • Hobbit
      • Nov 2002
      • 372
      • Jacksonville, FL
      mounts
      Since I now have 3 xs's (what is the plural of xs anyway?), how much per set?
      Walt
      80 XS11s - "Landshark"
      79 XS11s
      03 Valkyrie
      80 XS Midnight Special - Freebee 1
      78 Honda CB125C - Freebee 2
      81 Suzuki 850L - Freebee 3
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        waiting on quote
        will get a quote from the company that can make them in plural....
        I am doing a chain drive and want poly so there is very little frame flex, but still some vibe removal....chop
        MDRNF
        79F.....Not Stock
        • pggg
          • 1609
          • NZ
          Solid engine mounts versus rubber mounts.. mmm... for me anyway, even tho I ride twisty roads, out of a choice of stiffer handling or a smoother ride, I'd still prefer the smoother all round ride. What I heard - if you use rubber mounted handlebars to compensate for solid mounts, the handling usually feels 'mushy'
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            I would be interested in 2 sets. I have considered doing this for a while.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • 50gary
              • Apr 2006
              • 225
              • Saginaw, Michigan. USA Third stone from the sun
              I have aluminum engine mounts and solid mounted bars (homemade clubmans fairly short) and rode it tonight didn't even think about the mounts until I read this thread. I can't tell the difference in vibration?
              Cheers, 50gary
                Hey Gary,
                That's what I was wondering? My engine sorta rocks back and forth a little during hard accel/decels, so I figure my mounts are getting worn. Was thinking of putting solid ones in myself. Was wondering about machining out of billet aluminum to fit around the steel sleeves?
                But I'm already way behind in other projects, so that may have to wait awhile!
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  That's why I've liked the thought of polyurethane bushings. Nearly impurvious to weather and oils, more solid than rubber yet still has a bit of give to it for vibration dampening. Lots of pretty colors too (I'll take black).
                  Pat Kelly
                  • 50gary
                    • Apr 2006
                    • 225
                    TC, maybe I'm brain dead (insert joke here) but I can't tell the difference in the vibration. I figure it's a four not a single or twin it's not too shakey to begin with. My brother is a pattern maker and he made mine, govt. job they call it? They fit perfectly, simple machine work really I got the drawing from the UK site from a rider named "Alan" I believe? Mine were worn quite a bit so what did I have to lose? Having said all that the Polyurathane or Delrin bushings would also work fine, flip a coin?
                    Cheers, 50gary
                    • Dennyz
                      • 1151
                      • Olympia, Washington
                      I would like a set
                      DZ
                      Vyger, 'F'
                      "The Special", 'SF'
                      '08 FJR1300
                      • Mike F
                        • 99
                        • Amesbury (next to Stonehenge)
                        All the dimensions if you need them are mentioned in the previous thread here
                        Keep revving
                        Mike Farnworth
                        XS1100 E & XS1100 Sport Project
                        • andreashweiss
                          • 951
                          In case anyone wants some used stock ones. I have at least 5 complete sets. Plenty of life left in them. andreas
                          • Shappers
                            • Sep 2006
                            • 158
                            • Helsinki, Finland
                            Just something to bear in mind. .
                            The original rubber mounts have metal tubes bonded in them and large metal washers on the outer edges to contain the engine's sideways motion and to allow you to tighten the engine mounting bolts up hard. If you make new mounts from polyurethane you will need to spin up some tubes for the insides and get some large washers for the outer edges. For this reason I gave up on making some out of polyurethane and went instead with the solid alloy mounts as accurately drawn by MikeF. I came to this decision after 50gary reported back 'no vibes at all'. I also considered making them out of nylon instead, this would be a 'halfway' option.
                            Brgds, Shappers.
                            '84 Sport
                            • 50gary
                              • Apr 2006
                              • 225
                              Mike F. I'm sorry I made a mistake on the credit for your fine drawing. OPPS! ...and Happy Thanksgiving to all.
                              Cheeers, 50gary
