removing front turn signals
  • tranger03
    • Dec 2005
    • 19
    • San Juan Capistrano, CA
    If I were to remove the front turn signals (read: have already removed front turn signals) would it be possible to make the rear ones function again. I thought that wiring the two signal wires together would complete the circuit and thus allow the rear signal to work. However, it produced more of a missing front bulb condition (where the bulb is solid when signaling). Any help would be greatly appreciated.
    Thanks,
    Camron
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    try to measure the resistance of the bulb. Then put an appropriate sized resistor in place of the bulb on the signal side. I have never done it, but in theory it should work
    Acta Non Verba
    • mro
      • 4276
      • Hayward, California
      Hi tranger03
      Removing the front should not
      effect the rear or visa versa. (at least on a stock XS)
      My XS rear worked OK when one front bulb was out......
      mro
      • HobbyMan
        • 1801
        • Colleyville, TX
        strange... very strange..... on my stock 80g and 79f, if a bulb has a bad ground or is not there, the lights just stay on and do not blink.
        Acta Non Verba
        • mro
          • 4276
          Sorry,
          was not stock, had an auto parts store flasher on that one.
          Turns signals were stock tho
          Can get an electronic flasher that will flash even one bulb, self canceller won't work tho....
          mro
          • prometheus578
            XS-XJ Super Guru (RESIGNED)
            • Aug 2004
            • 4012
            • Olympia , Wa.
            "What a dim-bulb."
            MRO,
            We've always considered you to have a bulb burnt out, and whether your "Excessive Rear" works or not isn't really something we'd care to hear about.
              • 5062
              You'll need an electronic flasher for the blinking.
              • mro
                • 4276
                Ah well, could be worse ...........................
                Coulda been a "certifiable" Vespa scooter tech
                mro
