what you guys think of these if they work its alot better that new yammie slides
carb slides diaphrams
Tags: None
US$99 for a set of four is certainly less than new slides from Yamaha. They should do the trick for you.
You will need to carefully separate the two plastic collars that retain the existing diaphragm so you can use them to retain the new diaphragms.
I'll try to do a bit more searching through the archives - seems to me someone used to offer a service doing exactly this kind of diaphragm replacement.Ken Talbot -
something to go with the rubber
Have not tried em....
Someone want to be the ginny pig?
mroComment
Re: something to go with the rubber
how would these work with the stock BS34 carbs and slides? seems that the ufo is designed to be inserted into, and fill the cavity on the bottom of the existing carb slide. as the bottom of the carb slides on my 81LH are solid, these would be somewhat useless.Originally posted by mro
http://www.thunderproducts.com/u_f_o.htm
mroComment
thunderproducts UFO
I'm pretty sure these things are for regular slide type carbs( throttle cable opperates slide) not the CV carbs.If it aint broke....it aint mine!:(
80G The Big unit
72 BSA Rocket Three "Main Squeeze"
84 GS1150ES "Big Sue"
79 Special (Tomcat's) as yet unnamedComment
Flat out don't know.
From reading there "add" sounds like would work on our carbs, but..........
78/79 and 80/81 BS34'4 round slide's are different dia..., and they don't acknowledge this on there site. Would need to call there tech support to find out.
mro
btw, why do you think I postedSomeone want to be the ginny pig?
