Low rpm engine hesitation
  • turbodave_98
    • Feb 2003
    • 59
    • Rancho Cucamonga CA, USA
    I have a light hesitation on my 80 G model. after warmup it seems to be gone. Do I have a problem with:
    Carb sync?
    old plugs?
    other??
    Have not changed the plugs and am getting about 40 mgp around town and road. Appreciate any assistance. Thanks
    Turbodave:
    Running Against the Wind
    Never forget our POWs/MIAs
    Iron Butt Association #14500
    It could be the plugs are out a little larger than spec. on the gap, and or the pilot jet is just a little lean until the bike warms up. The plugs are the easy "first fix", so I would start there.
    Ray
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      These beasts seem to be cold blooded. Checking and fixin, if needed, old plugs, carb sync, ect would be a good place to start. Could even be a low battery. I know when I ride mine around in town for a week, I can never get the battery to fully charge so I will stick it on the maintenance charger a couple times a week. Of course,on weekends, a nice 2hr ride at speed in the morning is THE BEST way to charge a battery.
      • turbodave_98
        • Feb 2003
        • 59
        Thanks to both of you for the info. Will start with the plugs.
        Turbodave:
        • missinglink
          • Oct 2004
          • 59
          • Middletown, Delaware
          FWIW. I had an issue where I had a hesitation around 2.5K to 3K rpm. I chased it around until I found that the two caps on the vacuum ports on cylinders 1 and 4 had hardened to the point that they weren't completely sealing the ports. I replaced those caps and the problem went away...
          Missing Link
          Keep the Shinny Side UP!!
          • turbodave_98
            • Feb 2003
            • 59
            Thanks for the vacuum tip. Had not thought of that.
            Turbodave:
