In dealing with a fouled tank, I cleaned it as best I could without trashing the paint.
Understanding that gunge would be an issue, I took out the octopus and plugged the prime side of the petcocks.
I installed the small sintered bronze type inline filters which work well at trapping chunks. I have been through two sets in as many months. I used those because I could not find any paper type small enough to fit well.
Today, I did the third, and I hope final, carb teardown for this year and found that a lot of sediment was still passing the filters and being deposited on the head side of the butterflys and in the bowls. Looked to be red varnish type gunk. Been running Seafoam in the gas.
While at the Zone picking up more Gummout, I found some decent sized paper element filters for the same price as the sintered ones. these new ones have a lot more surface area, so I think they will last longer and should trap the fine particles better. They are about 1.25 diameter and about the same length not including the barbs, so they fit well just under the stock filter boots. Found them on the rack by the PCV stuff.
