I have oil dripping off the end of the cam chain tensioner assembly on the front of the engine. I am not sure if it is leaking around the plug at the end or the adjustment bolt.
If I set the crankshaft to the appropriate position for adjusting the cam chain tension, can I remove this assembly to replace the "O" ring on the bolt and possibly silcone around the plug?
Will it be straight forward to reinstall this assembly?
Thanks
Thanks
