Final Drive Transplant _ Kudos 2 Chop!
  • snowdog51
    • 348
    • st. paul ,mn
    #286
    dom steel
    xschop what is dom steel .
    bill
    bill hane
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #287
      DOM
      Drawn over mandrel.....It is structurally much stronger than the other tubing. It welds great to the steel of the XS11 swingarm with just a wire feed welder with flux also.....
      MDRNF
      79F.....Not Stock
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #288
        AlanB
        Hey Alan, what steel did you use on that nifty braced swingarm I saw of yours? very trick piece BTW.....chop
        MDRNF
        79F.....Not Stock
        • snowdog51
          • 348
          • st. paul ,mn
          #289
          dom
          sounds like the good stuff thats what i'm going to use .
          bill
          bill hane
          • AlanB
            • Oct 2006
            • 705
            • Scotland
            #290
            Hi XSChop,
            Sorry; I don't know anything about the spec....... I bought it already modded.
            It was taken from a bike imported from the USA, So someone on your side might be able to help?
            AlanB
            If it ain't broke, modify it!
            • subike
              • 167
              • Christchurch New Zealand
              #291
              After reading this entire thread, thinking of the argument,
              "" it will be too hard on the transmission""
              Sorry I had to laugh at that. There is no way that this can put extra load on anything other than your ego at the lights when you get left behind by that bike you use to beat.
              But, and correct me if my idea is wrong.
              When the XS was released, it was the quickest bike around,
              the designers and engineers at Yamaha built a bike that was very quick or fast. Well the first ones had 160mph clocks, and we know that with the gearing if the XS this was not possibile, or was it! And soon the clocks were changed to read 140mph, then again to a lower speed rating.
              Import laws can restrict the design of any vehicle to come within spec of the country it is sold new in.
              Was the XS750-850 diff ratio the original ratio intended for the XS11? Was it the ratio that the engineers did all the testing on at the factory test track? Was it their intention to use this ratio for the XS11 , BUT when released to the world as a production bike, it was too fast!
              So the quick way of slowing down a very fast bike, and still give it performance was simple, change the diff ratio.
              So all those Fast diffs intended for the XS11 now went into the tripples, to give them a boost? or to just use up the production stock.
              OK the fuel ecconomy was bad, but the 1/4 mile times were impressive for the xsessive and it sold well. Will we ever know?
              The XS750-850 mod is the best mod I have seen for this bike, I have been able to access one here in NZ,
              I managed to do a swap with a friend who owns an XS850, he now has my XS11 diff in his bike and it is stupidly fast compared to before.
              His diff is on the shelf waiting to go into my XS11 as I put her back togeather this winter.
              Oh Yeah, I guess you guys are enjoying you summer out riding the high ways . Have fun with the better gas mileage this mod has bought us all.
              But then is it a mod, or a return to what the designers intended in the first place. A thought to ponder as you eat up the highways.
              http://i139.photobucket.com/albums/q...e/DSC00009.jpg
              1980 XS1100 Std English Assembled, 378k miles
              In stock untouched contion.
              http://i139.photobucket.com/albums/q...e/seatside.jpg
              1979 XS1100F Std NZ new,
              Mikes XS coils
              Jardine 4-1
              Pod filters
              Harley Davidson Rear Fender
              Bullet signal lights
              Twin 75mm headlights
              Self made single seat
              • snowdog51
                • 348
                • st. paul ,mn
                #292
                i have a final drive 4h7j0 is this ok for doing mod it has a shaft stuck in it
                bill
                bill hane
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #293
                  checking
                  Hey Dog, just turn the FD over and mark the drive splines (in and out) and count the number of turns the input spline turns in relation to the wheel hub splines.
                  MDRNF
                  79F.....Not Stock
                  • cowboybob998
                    • Mar 2009
                    • 371
                    • KC MO
                    #294
                    what happen
                    Originally posted by MAXIMAN
                    First let me say this is absolutely the most straight forward mod I’ve ever done to my Eleven. And the results are spectacular. I am so utterly please with this modification I would recommend it highly to any Eleven owner that is not pre-occupied with ¼ mile times. If you want a top end – gas sipping XS11 this mod is the BOMB SCHNIZZLE. You won’t regret it. Besides it is so easy to do (other than a few hours of time) you could easily revert to the OEM drive if you want lower gears.
                    Secondly I must pay “kudos” to Chop (xschop). I nominate Chop for coming up with the coolest mod for 2006. I’m not sure what inspired him to experiment…and I am not sure I care to know. IT WORKS! The rev reductions are not only real but are very significant. At the end of this procedure I will post my real world results. In short they are outstanding.
                    I stripped all the old paint (silver) off the unit as I will paint it black to match the oem drive. Notice the XS750 has lubrication (spooge) holes in the base of the gear coupling. The 750 shaft also incorporates an oil seal that allows oil to circulate into the coupling house and lube the drive spline. The seal on the 750 shaft contains the oil in the gear coupling.
                    Also notice how the spline are recessed into the gear coupling. This recession is where the shaft seal seats to retain gear oil. The Eleven does not employ this style of lube system. The Eleven has no “spooge” hole and uses instead grease. Personally I think the Eleven is a superior system. With the Eleven there is no possibility of oil seal failure and thus leaks. So I sealed the spooge holes in the 750 drive with liquid gasket and covered them with a standard ½ flat washer (the perfect size by virtue of serendipity).
                    First to remove the pinion retainer nut as seen above you’ll need to have some way to hold the ring gear backup while you break the pinion retainer. I used an old XS wheel I had , then a 22mm socket on an air impact.
                    Next I removed the pinion assembly. When Chop removed his he said only the gear coupling came out and he never saw the pinion gear. My didn’t break there. The whole pinion assembly came out. No big deal.
                    The gear coupling is what receives the splines on the drive end of the shaft. Remember the lube holes and pinion shims. We’ll touch on these later.
                    After tapping the gear coupling on the floor, you should see a retainer nut (22mm) and a washer plate…and maybe a couple bearing spacers. Don’t freak if yours doesn’t have a spacer. This was the way it was manufactured. I’m guessing slight variations in machining would require different spacers for any individual housing. Much like the pinion and ring gear shims. No two drives are identical with this regard.
                    The replacement washer (1/2 flat washer) just so happens to be a perfect replacement to seal the spooge holes. I’ve only ridden mine about 30 miles with no leaks. But Chop has several hundred miles on his unit with no problems.
                    Next I pumped a little liquid gasket (Right Stuff – NAPA) into the spooge holes. This sealant is very effective especially in low temperature applications (less than 450 degrees). It will seal even on an oily surface. However to be sure …clean all surfaces with carb or brake cleaner and let dry.
                    Next put a thin film of sealant on the back of the washer. Replace the spacers (if applicable), then the ½” washer, and pinion retainer nut. Then tighten by hand only.
                    Now put a little sealant around the bearing housing…where it seats back into the drive housing. This will insure a good seal so no gear oil will leak from the interface. Yes yes there is an o-ring seal but I am always extra cautious. Besides the OEM housing appeared to have Yamabond on it upon disassembly.
                    Next slide the re-assembled pinion assembly back into the drive housing. Make sure the pinion shims are in place…and not laying on the floor somewhere. This is critical since the entire drive was shimmed for gear lash at the factory.
                    Also when re-inserting the bearing housing into the drive...pay attention to the lube hole in the bearing housing. They should line up with the cavitation channels on the inside of the drive housing. These channels allow oil to freely flow from the gear spinning into the lube holes and around the pinion bearings.
                    Next take a couple of the shaft housing nuts and some extra washers and snug the pinion assembly into the drive housing. This will seat the O-ring seal and the sealant you just applied to the bearing housing.
                    I did all these preliminary steps before I ever disassembled the OEM drive. At this point I let the XS750 drive sit overnight so the sealant would cure. I don’t think that is absolutely necessary, but I took the precaution.
                    Next (the following evening) I began the arduous process of field stripping the Eleven’s OEM final drive. Remove the rear wheel. Then remove the left shock from the drive housing. Next break the four shaft housing nuts loose from the OEM drive and slide the drive gear coupling out of the shaft housing. After this you’ll see the Eleven’s shaft remains in it’s housing.
                    Now you can measure the distance of the shaft face to the housing face. Then measure the distance of the XS750 drive housing face to end of the splines. This will tell you exactly how much spacing you need for a collar or length to extend your shaft. Depends on which route you take. In either case it turns out you’ll need about 5/8 to 11/16 inches ( 16 to 17 mm).
                    Next remove the shaft from the housing. The service manual recommends a slide hammer. And that is what I did. With two bearing puller arms and a slide it popped right out. Pull the circlip off the shaft. It won't be used again.
                    The two options for shaft modification will be discussed here: 1- spacer option ; 2- shaft extension.
                    The shaft extension will comprise cutting a stock XS11 drive shaft and stretching it by 17mm, using a collar and pins to secure it. I took a spare shaft I had to a reputable machine shop. The machinist told me the only way he could extend the shaft would be to collar and pin it. He said (and I quote)”…that shaft is harder than the hubs of hell…” In order to weld it he would have to heat the shaft and allow it to cool very slowly to soften the thing where he could cut it and weld it. If he tried to TIG the hardened surface he assured me the weld would break. In order to weld it the estimate for the process was not going to be cost effective. So I told him to simply cut it an collar/pin it.
                    The second option is actually the one I chose for several reasons. One is cost. Another simplicity. But the most important is strength. With a shaft that has been cut …then collared and pinned …the original material has been compromised. Even a welded shaft…if you chose to spend the money…would in my opinion be weaker than the spacer option. Because the original shaft would still have to be cut …collared and welded.
                    There is no need to jump through all these hoops when a simple spacer (copper bushing) can be made to effectively accomplish the same task. Upon studying the Eleven’s splines that interface with the U-joint yoke I could see that about 24 mm of spline is being utilized. Notice the 3mm or so splines beyond the circlip groove are not used in the OEM configuration. These splines protrude past the u-joint yoke receiver and a circlip holds them in place. I have yet to ascertain why the circlip is there. There is no way for the shaft to ever come out of the yoke once in place. The circlip is appears to be some “over-engineered” design.
                    Next I cut a ¾ inch copper sweat coupling (like you’d find at a hardware store)…I cut it 16mm long.
                    Then I slipped it over the shaft. At the drive end of the U-joint spline I slipped a 5/8 x 3/4x 1/16 O-ring to act as a retainer for the copper spacer. It will hold the spacer in place as the shaft spins reducing wear to the copper. I also coated the shaft splines in that area the collar covers with RTV to help hold the copper in place and reduce vibration. I don’t know that this is nessecary but It can not hurt. Then at the yoke end of the collar I slipped another O-ring. In theory this will keep the copper from rubbing directly against the yoke housing and should reduce wear to the end of the collar. And again – if the O-ring fails overtime it’s no big loss. The o-ring can’t hurt anything…it can only help.
                    After all this modification you can now see there is still 21.5 mm of spline length to engage the yoke. We’ve only lost less than 3mm of spline length. This should barely compromise the strength of the spline interface. Plus using this mod method we have not compromised the torsional strength of the shaft. And last but not least…this method cost a fraction of the other. Again…kudos to Chop for figuring all this crap out. I am merely the messenger relaying the procedure to all the brethren.
                    Next I pulled the rubber boot of the shaft housing away where I could hold the U-joint yoke straight to re-insert the shaft. Make sure the shaft is full inserted. Now with the copper spacer the shaft will no longer be recessed into the shaft housing. It should be nearly flush with the end of the shaft housing…actually mine protruded about 1 – 2 mm.
                    Next I removed the shaft retention spring from the Eleven’s pinion assembly and swapped it with the 750 spring. The 1100 spring is slightly longer and should do a better job of keeping the shaft fully engaged at the yoke end. Not necessary…just my method.
                    Next grease the inside of the gear coupling splines really well. Now slide the 750 housing up into the 1100 shaft housing. You’ll have to turn the wheel splines to help line the gear coupling splines up to the shaft so they will lock. When you get it sync’d the drive housing will seat flush against the shaft housing. Install the four housing nuts and tighten.
                    Don’t forget to fill the 750 drive with 90 wt gear oil. What shame to do all this work only to burn up the newly installed drive. Oh yes …and pump the shaft housing full of grease...you know at the shaft housing grease zirk. Dan Hodges tells me the spec calls for 30 cc of grease and that a standard grease gun is 1 cc per stroke. Do the math.
                    Re-install the rear wheel (grease those splines slightly too)…button and bolt everything back up. Now RIDE!!! And watch you gas mileage FLY!!! You top end speed should be to shabby either.
                    Cody
                    What happen to the pics
                    , getting ready to do the swap and went to this and i cant get the pics, says they have been move or deleted, does any one know where they are
                    1979 xs1100 f
                    142 main, 45 pilot, Jardeen crosover 4/2, no air box
                    floats @ 25.7
                    1979 xs1100 F
                    1978 gl 1000 goldwing
                    1981 gl 1100 goldwing
                    !986 venture royale 1300
                    Just an ol long haired country boy, come to town to spend some egg money
                    when ya get bucked off, get back on
                      #295
                      The person got banned and moved the pics...
                      • cowboybob998
                        • Mar 2009
                        • 371
                        • KC MO
                        #296
                        Well thats a fine howdy do, ya know i think i may have saved this some where, i hope, if not gess i will figure it out, got a couple of things going on here at the same time, gona strech the swing arm and do the rear drive swap at the same time
                        1979 xs1100 f
                        floats @ 25.7
                        1979 xs1100 F
                          #297
                          check your pm's
                            • 3193
                            #298
                            Or go here..
                            • STEPPENWOLF
                              • Jan 2007
                              • 4188
                              • CINCINNATI OH
                              #299
                              Originally posted by Rasputin
                              Good job Rasp
                              DGXER did my final drive a year or so ago,best thing ever for the bike.
                              Took a bit of getting used to the rpm's at lower speeds and I stll screw up from time to time but I won't go back to the orginal final drive.
                              '80 XS1100 SG
                              • b.walker5
                                • Feb 2009
                                • 1745
                                • Invercargill, New Zealand
                                #300
                                If anyones interested I have that article saved as a pdf on my hard drive. Happy to email it to anyone that wants it. PM me if you want.
