multi part question
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    multi part question
    Today at school it rained lightly. I keep a nice cover over my bike and park it under a tree every day. This helps prevent vandalism too. When I came out to take the cover off, brake fluid had leaked out of the reservoir on to the tank emblem. THe plastic is completely broken into a million pieces and the emblem is unusable. Thankfully, due to surface tension, the fluid stayed behind the emblem and did not ruin the rest of the paint on the tank. Here are my questions: #1 Are OEM emblems available?
    #2 I can't figure out where the fluid is leaking from the MC, What should I do to find the leak? #3 What is the best way to paint/ seal the peeled paint behind the emblem?(OEM Diamond Silver)
    I can't understand why the MC just started leaking. I haven't had any trouble with it all summer. Any help would be appreciated. Thanks in advance
    Acta Non Verba
  • randy
    • Dec 2003
    • 4521
    Hobbyman;
    #1. - Sorry to say, OEM emblems are no longer available new. Ebay is a good bet
    #2. - There are four places the mc can leak:
    -the cap - large rubber bladder thingy can crack with age.
    -under the reservior - large O-ring
    -the piston - rebuild kit
    -the banjo - new crush washers
    Surley with that much fluid leaking you can see the fluid trail?
    #3. -neutralize the brake fluid with soapy water. If it ate through the primer, re-prime the bare metal. Don't think you can match the factory color, so a re-paint may be in your future, but at the least get the bare metal protected or it'll rust.
    • HobbyMan
      • 1801
      • Colleyville, TX
      I think I have isolated the leak. It is eather a small crack in the reservoir which I cannot see, or as I recall, there is a big O-ring at the base of the reservoir. the reservoir does not appear to be available and the O-ring is not listed in the parts. Does anyone know where I can get them?
      Acta Non Verba
        Andrew
        I know a place in Bedford that has the O rings.
        • HobbyMan
          • 1801
          • Colleyville, TX
          Can you PM me the address? I have put the many fractured pieces back together on the emblem and I filled the backside impressions with epoxy. This might hold it together well enough. What would be the best way refinish the emblem. the gold is ok, but the black has peeled off. There appears to be some kind of clearcote on the outside. What should I spray as a clear over the whole thing?
          Acta Non Verba
          • petejw
            • 2269
            • sydney australia
            hi hobbyman
            theres a place in aus that does replica
            badges, heres the link.
            Badge Replicas Australia specialises in high quality motorcycle tank and side-cover badge replicas for , Suzuki, Yamaha, Kawasaki, Laverda, Benelli, Moto Guzzi, Ducati, Other Japanese and some European and American brands. We also supply classic Suzuki parts.
            my mastercylinder had also leaked, it was coming
            from the plastic sight viewer, had polished
            mastercylinder and rubbed the plastic to hard,
            leaked all over my emblem as well.
            hope this helps
            peter
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • chopwatchagot
              • Oct 2006
              • 81
              • Prescott ValleyArizona
              Hobbyman, Check the "Tank, Sidecover, Emblem" thread. There is some good advice there.
              Dean
              If it aint broke....it aint mine!:(
              80G The Big unit
              72 BSA Rocket Three "Main Squeeze"
              84 GS1150ES "Big Sue"
              79 Special (Tomcat's) as yet unnamed
              • HobbyMan
                • 1801
                • Colleyville, TX
                I may have found a replacement emblem, but I am not sure yet. I have been keeping an eye on the emblem thread to see what comes up. Today I pulled the old o-ring and it is definitely the culprit. It is too big and the inner surface is rough. Why did it just start leaking all of a sudden? I would have noticed before. I didn't even notice that my emblem was destroyed untill after I noticed the "wet" MC. I have a line on a professional paint manufacturer that speciallizes in classic automotive paints. This place made the paint for my friend's restored 1971 SS454 chevelle. They have excellent quality. I will see what they can do. I guess I should have replaced EVERYTHING when I originally brought this bike back to life. I decided to use my time wisely by recleaning my carbs since my bike is out of action. Since my #2 carb got temporarily pluged going to the Talihena rally, I have been meaning to rebuild them. I am glad I did because I notice that my floats were ALL leaking a little. THis was causing my long starting trouble. THe gas has been draining out of the hose and when the engine was being cranked, it was taking time to refill the bowls to the normal level. Now I have some Inline fuel filters(finally). I guess it is good to have an occasional maintanance weekend to fix and clean everything.
                Acta Non Verba
                • HobbyMan
                  • 1801
                  • Colleyville, TX
                  Well I have some good news. I finally recieved my new emblem and I am impressed. I decide to take a gamble with speed and sport inc. I know that some people have had trouble with their ebay auctions, but I was just going to order it directly from them. It doesn't look exactly the same, but the part numbers do match up so I am happy. It fits nicely. I also git a few other NOS stuff really cheap from them. For me they were AA++ Anyway, all that is left is to fix the paint on the tank around the emblem.
                  Acta Non Verba
