Broke pressure plate
  • GNEPIG
    • Apr 2005
    • 1647
    • fl
    .. WOW! sweet fix!.. i would have thrown it out and gotten one from one of the parts motors on the floor.. but thats great ,everyone dont have parts laying around like that ..
    .. my first thought was of the balance of the part also then i read somone else had the same concern just put another stud the same size directly across from it or fill them all in to be sure.. ..the extra weight might smooth out some vibrations from this point
    .. MAXIMS balanced clutch baskets
    • gaffer77
      • Jul 2004
      • 444
      • gloucestershire england
      amazin rescue job !!it's good to salvage!!i was reading somewhere about spacing a worn pressure plate ?? never looked at clutch yet goin to get to grips soon!! mine slips now and again
      just wanted to know the pitfalls of pressure plate ,they say you cant get em any more??mine may be fine and i have a complete clutch on way for spares do the pressure plates ware??
      i thought it'd be new springs cable and all plates or clean up the metal plates and replace the friction plates and cable ,adjust as
      per manual and clutch would be good again??
      so just to confirm again sorry!! can the pressure plates cause problems too!!
      Don't put all yer eggs into one basket ,,,case
      • SG-Olli
        • Apr 2005
        • 118
        • Solingen, Germany
        Originally posted by Pat Kelly
        I wonder if threading and studding all the posts when replacing the clutch would strengthen this weak spot on our drive trains? Might prevent accidental breakage on reassembly.
        Also, doing this to all would keep this spinning part balanced. A couple of ounces off @ 8,500 RPM might cause a vibration or harmonic.
        Just thinking out loud here.....
        First of all: Great job!
        Threading and studding will definitely strengthen the part. I am not sure if it needs to be balanced anyway. If so the complete clutch pack should be, including the plates. Did anybody mark his before disassembly?
        @ Pat the clutch does not do 8500 rpm, at least not if you keep the engine below 14000 rpm (primary drive ratio 1.657)
        XS1100 and XS650- what do you need more?
        • MAXIMAN
          • Jan 2005
          • 1817
          Gaffer77
          I've not noticed "worn" pressure plates. That's what the friction plates are for. Motorcycle clutches are pretty much a "disposable" item like brake pads...tires...etc.
          The way I "re-installed" the clutch pack was with a impact wrench. I set the gun up to apply about 45-50 ft-lbs of torque. Tested it on a nut elsewhere and set the impact gun accordingly.
          Then I just tightened the nut on the bike with that setting. It's not exactly 51 ft-lbs but close.
          his whole clutch assembly is made of pewter or something really light.
          • MAXIMAN
            • Jan 2005
            • 1817
            I assume you mean mark it (as if it was balanced from the factory) and go back the same way to keep it in balance?
            I've never done that on any clutch for balance. I have marked things upon dis-assembly to keep it all straight going back. Good idea.
              .... my avatar? I just got tired of the old one, thought this one looked interesting...
              • MAXIMAN
                • Jan 2005
                • 1817
                Yeah well I never even knew what it was.
                BOY....I DO NOW!
                  Maximan, actually Kens' avitar is the clutch hub for the rear wheel. The splines that you can see is where it engages with the final drive. Just thought you'd like to know.
                    Hey Gaffer,
                    I've heard of folks having worn pressure plates!! The extra plate they talk about is a steel plate, put in the middle of the pack, so you have 2 steels next to each other, then sandwiched like they ordinarily are with fiber/steel outwards on both sides of the double steel sandwich!!! This will provide a mm or so more thickness to take up what was lost from the pressure plate(s)!
                    HTH.
                    • MAXIMAN
                      • Jan 2005
                      • 1817
                      John
                      I see the splines now. It looks similar to the star plate on the clutch too.
                      • MAXIMAN
                        • Jan 2005
                        • 1817
                        Oh yeah and thanks for all the praise on the fix. I am pretty sure it will last indefinitely. There's really no way it can move and that steel stud it far stronger than the pewter they originally made the piece from.
                        Having said all that BS...know this...I am NOT that sure of it. And as soon as the new plate comes in I will replace it!
                        Like I told Dan Hodges...I would puke blood IF...just IF... that thing broke in the middle of the Nevada desert.
                        However...like I told him...there's coming a day when we'll have no choice but to rely on our own wits to fix these things. I think we are getting close to that regarding other parts including the TCI...right Randy?
                        • gaffer77
                          • Jul 2004
                          • 444
                          thanx TC That was it exactly!!!!!!!!!!!!!!!!
                          Amazin !!! i knew there was something about it!!!
                          • Pat Kelly
                            • 3046
                            • Golden Valley, AZ
                            Ressurecting "This Old Thread"
                            Cody, did you replace the pressure plate or are you using the 'repaired' one? If so, I'm guessing it's holding-up good.
                            Pat Kelly
                            <p-lkelly@sbcglobal.net>
                            1978 XS1100E (The Force)
                            1980 XS1100LG (The Dark Side)
                            1999 Suburban (The Ship)
                            1994 Dodge Spirit (Son #1)
                            1968 F100 (Valentine)
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              pressure plate
                              Hi Cody, I still haven't gotten to my clutch fix yet, I didn't know that part was the pressure plate. I had an entire clutch assembly here for the "T.C.extra steel plate" mod if I decide to go that route. You still are more than welcome to have....nice engineering exploits....chop
                              MDRNF
                              79F.....Not Stock
