Rear Gear Ratio?
  • XS11Trike
    • Oct 2006
    • 7
    • Lonedell, Mo.
    Rear Gear Ratio?
    Can someone tell me what the rear wheel gear ratio is for an XS11? I have some rear axle ideas for a trike but need to have this info as a starting point, Thanks!
  • ccogswel
    • Jun 2005
    • 302
    • Bowling Green, Ky
    Hi XS11Trike,
    Try this link. It's Chops Final Solutionhttp://www.xs11.com/forum/showthread...threadid=11451
    This should answer any questions you may have and then some. I think the rear is something like 3.3:1 Hope this helps.
    Chris
    79 XS1100 Standard aka: Mutt
    Gimme Fuel Gimme Fire!
    • XS11Trike
      • Oct 2006
      • 7
      • Lonedell, Mo.
      Thanks!
      I'm wanting to use a rear end out of a Honda CRV or a ford Escape or whatever the Mazda model is. I don't want a Hardtail / chain drive like my old HD trike. If I do this I'll probably have to get rid of my XS650.
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        FD ratio
        3.3 to 1 is stock xs1100. 2.9 to 1 is the xs750/850 ratio. Hey trike, take a look at a 78-87 XJ6 (jaguar) rear end.They are IRS and can handle lots of power, also the discs are located centrally near the axle. They are very abundant and I have seen a few diff. applications....chop
        MDRNF
        79F.....Not Stock
        • 3IOH22A
          • Apr 2006
          • 11
          • Kingston Canada
          XS11Trike
          what is your time frame on this build, are you going to have a
          build thread on this or some other site.
          Reason I ask is I am planing to build a trike out of my XJ11.
          "An individual must enforce his own meaning in life and rise above the perceived conformity of the masses"
          • XS11Trike
            • Oct 2006
            • 7
            • Lonedell, Mo.
            Re: FD ratio
            Where are they abundant? I havn't done any searching as yet in the St. Louis area. Any junkyard? or a english specific supplier?
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              check local posts
              Postaroo is a multi-city free posting board. I almost bought a complete 87 xj6 for 500 bucks.they are cheap and abundant because the motors are expensive to build/repair. The chevy v-8 installs easily into the engine compartment. The company JAGS-THAT-RUN,that I did my s-10 v-8 convesion from, has the jaguar kit as well....chop
              MDRNF
              79F.....Not Stock
              • XS11Trike
                • Oct 2006
                • 7
                • Lonedell, Mo.
                Originally posted by 3IOH22A
                XS11Trike
                I'm probably a year out on starting the hands on part. Unless I fall into a deal on an XS11 like I did on my XS650. I also haven't completed all of my ideas on the 650 yet.
                • XS11Trike
                  • Oct 2006
                  • 7
                  • Lonedell, Mo.
                  Another Possible Issue
                  It just ocurred to me that drive shaft rotation may be an issue as well. Which direction does the drive shaft on an XS11 rotate?
                    I'm going to take a chance and say clockwise. The XS1100 "leaps" on a hard launch, so the pinion gear is trying to climb the ring gear. That puts the rotation clockwise, in my book.
                    But then, I may be wrong....( it did happen once, but I got a divorce )
                    Ray
                    • 3IOH22A
                      • Apr 2006
                      • 11
                      • Kingston Canada
                      Left side shaft rotates clockwise right side shaft rotates
                      counter clockwise
                      • 3IOH22A
                        • Apr 2006
                        • 11
                        • Kingston Canada
                        Rear end will need to be flipped to run forward.
                        • XS11Trike
                          • Oct 2006
                          • 7
                          • Lonedell, Mo.
                          counter clockwise
                          So looking at the shaft as it would turning a rear axle it would be turning the yoke?
                          • XS11Trike
                            • Oct 2006
                            • 7
                            • Lonedell, Mo.
                            Sorry for all the questions. I ran the chain driven axle on my Panhead Trike upside down as a big twin tranny drives on the left instead of the right like a 45 or Sporty but it was a greased rear end, no oil. Will a standard automotive rear end upside down without a problem? If it had drum brakes would I not need to swap those from side to side for proper operation?
                            • Trikerneil
                              • Dec 2005
                              • 141
                              • Wareham, Dorset, UK
                              Hi XS11Trike
                              The XS11 driveshaft rotates the wrong way for most car differentials. So you will have to flip the axle over or modify the middle gearbox so it rotates the "correct" way.
                              Some diffs can be rebuilt with the crownwheel on the opposite side to get the desired effect.
                              A lot of diffs these days have the pinion arranged so they don't run on the centreline of the crownwheel. This setup means that the pinion is "pulled" into mesh. If you invert one of these diffs the pinion will be pushed out of mesh. DAMHIK
                              If you flip a complete axle over you will have to swap the brakes end for end or you will get trailing shoe brakes which are not very efficient.
                              Have a look at my website to see how I tackled this problem
                              Neil.
                              Triking - it's a way of life!
                              www.trikenest.co.uk
