throttle body shaft seals
  • petejw
    • 2269
    • sydney australia
    hey guys
    the throttle body shaft seal
    should the cup face towards the butterfly
    which i think is correct or away from it
    thanx in advance
    peter
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • petejw
    • 2269
    • sydney australia
    amendment
    ive got the cups facing outwards
    to prevent air from being sucked in
    is this correct
    thanx again
    peter
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • randy
      • Dec 2003
      • 4521
      That's right. Cup faces out.
      • petejw
        • 2269
        • sydney australia
        Thanx randy
        i bought these from yamaha, the seals r to big
        and dont sit snugly on the shaft, the shaft isnt worn,
        now have to buy another set, the air was leaking big
        time thru them. i wont buy them thru yamaha again.
        any one know if mikesxs sells them
        and the part number and if they fit snug
        on the shaft,
        also after part no for the pilot jets 42.5
        from mikesxs
        thanx again
        peter
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          Probably expensive but another source that will have the correct seals is Rob Reil at www.motorcyclecarbs.com
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • petejw
            • 2269
            • sydney australia
            Thanx Pat
            ive orderd the pilot jets from mikesxs
            will look around at a bearing and seal shop
            from near here and see how i go.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              Carb parts
              What Pat said. www.motorcyclecarbs.com will have your parts
              • randy
                • Dec 2003
                • 4521
                petejw,
                Read the posts above yours. Getting the seals from Rob Reil is a crapshoot as well as Yamaha. You need to verify the carbs you have in order to get the right seals. The ones I got from Yamaha (through bikebandit) were a perfect fit.
                Early models '78-'79 had BS34II carbs, later models had BS34III carbs.
                • Brian_D
                  • 355
                  • Gardner, KS
                  petejw,
                  The butterfly shaft seals from MikesXS fit perfectly on my 81LH. I have not began the rebuild on my 79F, but they should work for it as well.
                  Sorry, forgot to include the part number:
                  Throttle Butterfly Shaft Seal - Fits: Stock Mikuni BS38 CV carbs on 70-79 650's
                  Part #48-5021
                  $5.00 USD EA.
                  • randy
                    • Dec 2003
                    • 4521
                    petejw;
                    Sorry, I got confused between screens. the posts I referred to are here. I had trouble with the seals from Rob Reil. And, BTW, he never did respond to my complaint, just said "use 'em, they'll be fine". Right. Read through the whole thing, hope it helps!
                    seals thread
                    • petejw
                      • 2269
                      • sydney australia
                      Thanx 4 all the help guys,
                      Ive ended up going to a bearing shop
                      and hes hopefully going to order me sum,
                      im spewing in that i bought those seals
                      at the beginning of the year, and replaced all of them
                      and now have to do it all again, as long as it works this
                      time ill b happy enuff, its a beautiful day and the bikes
                      sitting in the garage. i hate that!
                      hopefully ill get them 2morrow and post part numbers.
                      thanx again
                      peter
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • petejw
                        • 2269
                        • sydney australia
                        Randy,
                        was reading that other thread of yours,
                        did u end up fixing ur seals up,
                        in proms thread he gave 2 part numbers
                        Checked the microfiche. Used a '79f(BS34II) and an H model(BS34III)
                        BS34II was 2A2-14997-00-00
                        BS34III was 256-14997-00-00.
                        the ones i had ordered are for the bs34III
                        was wanting to know from anyone the differences
                        in the different model seals.
                        man im having a hard time getting the right ones.
                        again thanx heaps
                        peter
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
