Left/ Right crank seals
    Are the crank seals interchangeable for each side? I see it's a different part number, but does that necessarilly mean it's different? I have an extra from doing the right side, and didn't know if anyone knew for sure that they can't be swapped. Thanks.
  • Yamaniac
    • Jul 2005
    • 262
    • Stilwell, KS
    book says bigger OD one goes on left... pg 109 of clymers, pic 179
    but my book doesn't include the XJ.
    Yamaniac
    '79 xs11 sf - WidowMaker, 750 final drive
    '80 xs1100 sg- ENEMY#1 parts bike no title(free)
    '79 f- frame and swingarm (and title)
    '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
    '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
      They are not the same at all. The right side seal is smaller, and they have a "rib" that fits into a locating groove in the crankcase. With an OEM seal, the left side must be done by splitting the cases, but I have an OEM right side seal that the rib has been eliminated. Removing the rib is something that is new, because I did the seals in my bike a few years ago, and both of the OEM seals had ribs. I bough some more last year, and the right side was minus the rib, but the left side still had it. I have read here that someone has found a left seal with the exact same dimensions that doesn't have the rib, and can be installed without splitting the cases.
      The XJ uses the same seals as the XS.
        I figured they'd be the same (XJ and XS) The motor is a 78 XS anyway. There is a local shop here that seems to magically have every kind of seal or bearing that you can think of. If someone has a seal sitting around, any chance they also have a caliper, could you get me the inside and outside dimensions, as well as the thickness? I took the one for the right side in to him and he measured it... said he had them for about 1/4 what I paid at the local bike shop.
        ALSO
        I can't put my motor together because I have lost one of those measly little circlips that go on each side of the piston and hold the wrist pin in!!! I will check to see if my local shop accidently has one laying around on Monday... but in the mean time, anyone have a spare they could mail to me? Please?? I can send one back and replace it when I get one in from the shop, but their delivery times can vary if they don't have it in stock. Held up by a tiny piece of spring steel.... Sigh. I realized I had it in my pocket the other day... so I put it in a safe spot so it wouldn't get lost.... any hypnotists out there?? I'm tellin ya.... that mercury and lead paint is kickin' my A@@!
          Gotcha covered on the wrist pin circlip. PM me your address, and I'll get it out Monday. The stamp's on me.
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            The above link is in reference to replacing the left seal with a lipless version.... I need to do this myself as my left is leaking...
