Ok, this really sucks. But basically through the course of ill fated events my master link fell into the engine when I was trying to change the cam chain.
It fell straight down onto the crank gear. I ran and got a magnet tool from a friend, and was able to fish out the link part from under the gear, but I havn't been able find the side part of the link. I fished down there forever and I'm quite sure it's not in the cam chain cavity. I drained the oil and fished around in the pan through the drain spout. I reeeallly don't want to split the engine apart.
Anyone who has taken the engine apart know where that little side clip would end up if it fell into the chain cavity. I can't see, but I'm assuming there's a oil drainage opening below the crank gear.
Thanks
Thanks
Man, at least I didn't get it all back together only to hit the starter that first time to hear CLANK CLANK CLANK
I hate to say it, but you can buy a used head (And lots of times a whole motor) cheaper than you can replace several valves for.
