Resistance value (Not ballast)
  • audijunky
    • Apr 2006
    • 707
    • VA
    I have installed some after market turn signal and my lights just stay on. I have heard about adding a resistor in parallel to the circuits and was wondering what value should I use. I was going to buy a bunch of different values and experiment but figured I would ask first. Thanks fellas and enjoy the Avatar, what a hottie!
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
  • petejw
    • 2269
    • sydney australia
    U dont need to add anything
    just replace ur flasher relay with an electronic one,
    u can pick them up at any auto place cheap enuff
    use the 2 pronged relay.
    The only thing is that the blinkers wont cut out automatically.
    I only did mine the other day.
    Peter
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      L.E.D.s?
      you installed l.e.d.s correct? If so you need a true electronic flasher I tried a few and the best (true digital electronic) is K&S # 24-0005. DON'T put resistors on those leds. they get very hot and you defeat the purpose of the l.e.d.s to draw low current....chop
      MDRNF
      79F.....Not Stock
      • audijunky
        • Apr 2006
        • 707
        • VA
        No LEDs , just cheapo after market turn signals. singal bulb singal filament.
        • Trikerneil
          • Dec 2005
          • 141
          • Wareham, Dorset, UK
          What wattage bulbs are in the new turn signals?
          You need to know to calculate the value of the resistors required.
          Triking - it's a way of life!
          www.trikenest.co.uk
            Probably a stupid question.. but are you sure it's wired right? One side WILL stay on as a running light, but the bulb should have 2 filaments.. it will burn brighter when flashing. If you wired the wrong side, the brighter one will remain lit, while the dimmer one would try to blink.. and probably not see it.
            Or.. are you saying that you hit the turn signal, it comes on bright, but doesn't flash? If that's the case, another flasher is all you need.
            • MAXIMAN
              • Jan 2005
              • 1817
              TOD
              I bought some of the same lights. They have incandescent bulbs but they are low amp. The bulb number is 97. They will not flash with a stock flasher.
              So I chucked 'em and bought some lights with 1157 bulbs. Works perfect now.
              audi
              I think Chop has the answer. The 240005 he speaks of will flash anything. I think the specs on it have an amp range from 20 to .1
              • GNEPIG
                • Apr 2005
                • 1657
                • fl
                .. OH YEAH, and where does one go to see a better picture of this hottie?
                • mro
                  • 4276
                  • Hayward, California
                  Now that's my idea of a bad A$$ ride
                  mro
                  btw
                  if your oem flasher/self canceling units are good. Will work if used with 1157 bulbs in front and 1156 in rear. (bad/corroded connections/grounds can keep em from flashing too)
                  • audijunky
                    • Apr 2006
                    • 707
                    • VA
                    For a bigger photo of this babe and more go here
                    DC's Alternative Rock Radio Station. Wake up with Elliot in the Morning and then hang out with Mike Jones, Tamo, and Alex Mac!
                    Great pics all over this site.
                    Thanks for the replies fellas, I dont know the wattage on these bulbs. I think I am going to go with a different style to get running lights.
                    I got another problem though. I dont know if the PO added this or not but sitting on top of my TCI box was another smaller black box with some wires coming from the wire bundle spliced through it. The two extra leads that it created acted as turn signals. One had 12 volts when activated turn signal switch left, Lost when deactivated. The other had 12 V when activated turn signal swith right lost when deactivated. So I figured the PO added this to give him extra lighting for signals. So I connect everything, Brake light works normally running light when not braking and bright when braking. Heres the problem When I hit the turn signal switch left, the brake filament and running filament(in the brake light) alternate with the turn signal.The actual filaments alternate. when flasher on, brake light lights and running light out, and Vice versa. Flasher off brake light off,running light on. Wierdest sh_t I ever saw. Get this it does not do it when right signal activated. HUH ANy body got any ideas. obviously its wiring. Any one seen one of these smaller black boxes before?
                    • GNEPIG
                      • Apr 2005
                      • 1657
                      • fl
                      .. now thats hot!
                        Hey Steve,
                        That little black box sounds like the PO went and got some sort of trailer adapter lighting box for cars and wired it in somehow! I had to get one for my SUV, it converted my separate turn and brake lights into 1 circuit for my single brake/turn signal lights on my trailer! It probably isn't needed, and you should be able to remove it and clean up the wiring to your brake and turn signals.
                        • audijunky
                          • Apr 2006
                          • 707
                          • VA
                          The crazy thing is I pulled the TCI and the other box off the fender and out where I could trouble shoot and get a good look at the wires and now it acts normal. So I double checked everything a put it back together and it works fine. I dont know, I guess I had a short somewhere? Thanks for the reply TC
                          • jimboreeno
                            • 427
                            • Smithville, MO
                            I went through every plug I could find and used a brass detail brush on the contacts then some di-electric grease and replugged. The overall difference in the bike was quite noticable. The contacts get oxidized after 20 years or so and increase the resistance. Even if you don't get an actual short, your voltage is diminished.
                            JimBoReeno
                            My Ex!"Half-Breed"
                            '82 XJ1100 Maxim with
                            '80 XS1100SG Motor
                            Current Bike
                            2000 Indian Chief
                            Millennium Edition
