Cylinder head spec sheet
  • petemonster
    • Oct 2006
    • 2
    • MN USA
    Hey,
    Im currently remanufacturing a head for my friends bike.
    Basically I'm going to clean it, test all the parts, replace the bad ones,regrind the valves,and cams,resurface it ,and then give er a 3 angle valve job.
    What I need to know is,can anyone hook me up with the high and low limit specs for this head?
    It's a 79 xs1100
    Things I need to know before I start.
    installed valve height
    valve to piston clearance
    guide play
    recommended combined seat runout
    safe limit spring tension
    recommended RA for the deck surface finish
    Any info will help......I generally do auto and industrial engines, and all the manuals I have are for these applications.
    I have all winter to complete the project but would like to get started.
    Thanx =]
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    only info I have right now
    mro
    • petemonster
      • Oct 2006
      • 2
      • MN USA
      Very good thx
      What's really important is the installed valve stem height.
      The tips will need to be ground down to achieve the correct spring tension and valve lift,due to seat depth variance.
      Dont wanna smack into the pistons the first time around he he.
      But this does help somewhat ,so thank you.
      • mro
        • Oct 2005
        • 4276
        Except this
        mro
        • mro
          • Oct 2005
          • 4276
          Valve adjust: if you haven't a clue what shims to use, I'd start with a 230 and measure to find correct one. Have yet to see an installed one smaller than 240 and most common are 260 to 285 with a few going to 300.
          mro
