Master cylinder
  • Incubus
    • 1003
    • Austin TX
    Master cylinder
    Hi y'all. My master cylinder is shot. I'm keeping an eye on a couple on EvilBay, but I wanted to see, before I bid, which ones would work. Will the master from an XS650 or XS750 work both calipers adequately? Or do I need to hold out for an XS850 or 1100 or an XJ1100, which came with dual disc systems, to make sure I can push adequate brake fluid?
    Ideas, anyone?
    Thanks,
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Mikes XS has the kits for the front. PN08-0204.
    Unless the bore is shot out, no big deal to rebuild.
    XS1100SF
    XS1100F
      • 7735
      You want a MC for dual disks. The single disk unit will be harder to operate, and the handle will probably go almost to the grip. I got a brand new one from one of the online store, just can't remember the name...
      Ray
      • Incubus
        • 1003
        • Austin TX
        The bore on my MC is shot. The piston was corroded in and by the time I got it out the walls were scored. I rebuilt it, but it spews brake fluid all over everything when you squeeze the handle.
        Patrick
        1969 Yamaha DT1B
          Patrick,
          Both PNM and MIKESXS carries the 16mm bore dual disc type front MC, around $79.00 IIRC, standard hose fittings, and since you have the Standard, not any concern with the angle that the reservoir will be sitting at...the specials with the pull back bars have the reservoir more angled! I think it even has the mirror mount/hole!
          • jeffe
            • Oct 2004
            • 393
            • Westerville,Ohio
            The plastic reservoir on my front master cylinder fell apart when i was bleeding the front brakes. I was able to get one off of either a Yamaha Fazer or Radian for about $45 bucks . It had n=been taken offa wrecked bike and completely drained by the sdalvage yard. It hasa lower profile resevoir than the old stock and works just fine. I was told that the piston diameter had to be the correct size for a twin disc set up. And if so just about any Yamaa cylindershould work. They are located in Delaware, Ohio. (740) 362-5595 They specialize in newer bikes that ours but were very helpful in finding one that fit my 78E
            78E ... Gone but not forgotten
            2006 Kawasaki Concours....just getting to know it
              Free Shipping for either one!
              MikesXS:
              Master Cylinder Assembly
              Master Cylinder Assembly - 16mm bore. - Recommended for late dual disc Front
              brakes on 1977-84 XS650’s or single front disc brake (1972-76 650’s). Yamaha
              OEM type. Complete with brake lever, brake light switch, banjo bolt and washers.
              Part #08-0265 $79.00 USD EA.
              PartsnMore:
              DUAL DISC MASTER CYLINDER
              Dual Disc Master Cylinder Assembly. Yamaha Style - Alloy body Master Cylinder Assembly with Lever, Banjo Bolt, Banjo Bolt Washers and Brake Switch. High Quality , Low Profile Design featuring 16mm cylinder with 10 x 1.25 threaded outlet. Fits 7/8 inch Handlebars, Accepts Yamaha Style Left Handed Thread Mirrors.
              $76.00US EA.
              Part#08-0264
              • Incubus
                • 1003
                • Austin TX
                Thanks, everyone. I am going to have to look at one of those new masters after the credit card statement closes and I have new money again, T.C. That really looks like the way to go.
                The engine makes it go, but that really doesn't compare with the ability to stop. It's really rare that a fast takeoff will save your life, but consistent stopping will do that every time.
                Patrick
                1969 Yamaha DT1B
