Need a frame measurement.
  • The Dutchy
    • Jan 2006
    • 35
    • The Netherlands
    Hi guys,
    I'm working on a restore on my XS. Got nearly the whole bike parted out.
    I always found that the rear seat and rear fender seems to be low, sagging down a bit.
    What is the distance from the last collar from the frame to the centre of the swing arm axle ??
    I think my frame took some pounding. Between 45 and 55 mph cruising the bike handles funny, not in an easy straight line. This can also be caused by my rear tire and maybe shot bearings on the stearing, but while I have the bike stripped I also doing some check ups on the frame. Side Q are the frames on the special allso the same to the frames on the standards ??
    The Dutchy.
    Freedom is speaking the longing for life when the opinions of the ages inform your experience that death is all that awaits you.
    http://www.danasoft.com/sig/TheDutchy.jpg
  • pggg
    • 1609
    • NZ
    From "What is the distance from the last collar from the frame to the centre of the swing arm axle ??"
    hey D, can't quite figure what part of the frame you mean?
    • The Dutchy
      • Jan 2006
      • 35
      • The Netherlands
      Well, here's a pic before I started parting out.
      In the photo you can actually see my frame coming a bit down at the end. marked out by the yellow line.
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        Red line measures about 25 1/4 in on mine.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • Dennyz
          • 1151
          • Olympia, Washington
          The two frame rails under the seat should be straight from where they mount to the main frame at the tank mount all the way back to the rear fender mount.
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
          • The Dutchy
            • Jan 2006
            • 35
            • The Netherlands
            Thanx Dennyz
            Allthough as seen in the pic. the bars are straight except they are pointing down. I can't see any deformation or bending of the tubes while having a bare frame. Ships, what is going on here. Shorter springs. Anyone with a spring length measurement ??
            • xswilly
              • Jul 2003
              • 462
              • Hollis, maine
              I also got 25-1/4 measurement
              and mine is a standard
              here is a spring size, again this is a standard
              also a bare frame
              with a level laying on it
              hope this helps
              http://home.securespeed.us/~xswilly/
              78E main ride, since birth the "good"
              78E Parts, the "bad" fixing up now
              78E Parts the "ugly" maybe next year
              79F Parts
              80G Parts
              75 DT 400B enduro
              • The Dutchy
                • Jan 2006
                • 35
                • The Netherlands
                Thanks XS Willy.
                Measured the spring, it was at 7.8 inch.
                Total shock was at 12.5 (centre Eyes)
                Put a Level on the frame and at the rear mounting struds it is like 1"down. So now find the exact locatio where the frame is bent.
                I do have a alternative on a frame allthough it is from an E not an SF model. Are the frames the same, meaning is the angle on the front collar, the frame mounts etc.. the same.
                I have to dig into this one. Thanks for the nice pics XSwilly. You already put me one step ahead. Or is it backwards in this case.
