Gas Cap Gasket
  • xszgrider
    • Sep 2006
    • 46
    • El Paso, TX
    Gas Cap Gasket
    I just bought a 1980 XS1100G with low mileage. The bike is in great shape except the flip type gas cap does not seal well. I am getting gas fumes in my garage. The previous owner said the gaskets were no longer available. An suggestions would be appreciated. Thanks
    John in El Paso
    1980 Yamaha XS1100G
    2002 Honda Goldwing
    1977 Yamaha TY250
    1973 Yamaha TX750 (future project)
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Check out the plumbing section at your local hardware store. Take the old gasket along with you and match it against the various sink drain rubber seals.
    Ken Talbot
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I bought two from Mikes XS. The 650 cap gasket fits both my standard and special.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • wingnut
        • Oct 2005
        • 695
        • NC
        Are ya Sure?
        Are you sure the fumes are coming from the tank cap? Just for check the bottom of the air box. There's a small hole in the center. If you find any wettness its fuel from the carbs.
        wingnut
        81 SH (Daily Ride)
        81 XS 400
        Thomas Jefferson
          Hey John,
          Take a look at this thread , it shows the MikesXS gasket and how it fits the cap!
          But like Wingnut said, you'l want to check to make sure it's not from leaking carbs and a wet airbox!
          • xszgrider
            • Sep 2006
            • 46
            • El Paso, TX
            Gas Cap Gasket
            Apparently, MikesXS is out of the gas cap gasket that fits the 1980 XS1100G. It is their part number 20-0036 and they do not know when they will get any in.
            They only have the 20-0038 which is for the 74-75 XS650. I order two, but they would not work.
            I have been unable to find a gasket. I have been using an "O" ring which seems to work.
            Any suggestions?
            John in El Paso
            1980 Yamaha XS1100G
            2002 Honda Goldwing
            1977 Yamaha TY250
              • 7785
              Mike's XS
              Mike's XS is out of a lot of stuff right now. As much new stuff as he's coming out with for the XS650, I expect he's working to get resupplied. In the meantime call 650 Central. They've got most of the same goodies. www.650central.com
                Hey Marty,
                I just visited that site, and I can't find any gas gap seals at all!
                XSZGrider, I first used a large NEOPRENE washer I got from my local hardware store, just cut it to fit the gas cap, the glue I used wasn't very good, but the rubber made a good seal anyways!
                • xszgrider
                  • Sep 2006
                  • 46
                  • El Paso, TX
                  Gas Cap Gasket
                  Hi Marty,
                  Thanks for the information. 650 Central had the gaskets in stock, so I order 2. They were only $4.00 each.
                  Thanks again,
                  John in El Paso
                  1980 Yamaha XS1100G
                  2002 Honda Goldwing
                  1977 Yamaha TY250
                  • 80mdnt11
                    • Mar 2006
                    • 221
                    • S.E. IL./ Olney
                    Where did you find the cap gasket/seal on 650central? Gas fumes very noticable in the garage! Checked Mike's, still out of stock
                    "Elvira"
                    '80 XS1100LG
                      • 7785
                      Forget about what's on the website. Call them on the phone.
                      • 80mdnt11
                        • Mar 2006
                        • 221
                        • S.E. IL./ Olney
                        Thanks! Will do................................
                        "Elvira"
                        '80 XS1100LG
                        • xszgrider
                          • Sep 2006
                          • 46
                          • El Paso, TX
                          Gas Cap Gasket
                          I called them also. You have to leave a message and he will call you back. It was several hours later, but they did, and they were very helpful. I have already received my gaskets!!
                          John in El Paso
                          1980 Yamaha XS1100G
                          2002 Honda Goldwing
                          1977 Yamaha TY250
