Ok .... i do not have the dip stick 2 measure the fluid in the middle & final drive gear so i am asking can any1 tell me how i can chk it or tell me in "s (inches)how much shld be in there or is there another way.... also i need to know how much shld b in there & how 2 tell how much actually is..... it feels as if ssssshe is shifting hard & is why i want 2 know...... thanks 2 all of u who reply...
MIDDLE/FINAL GEAR Fluid CHK
Check out this tip: http://www.xs11.com/forum/showthread.php?s=&threadid=72
Has measurements on it. I think the rear diff hold .33 quart, but I don't have the book handy.Gary Granger
I wouldn't think the mid or final would have anything to do with the bike shifting hard, but it's a good idea to check it/change it.
Have you adjusted the clutch (not at the lever)? Recent oil change in motor?Mike * Seattle * 82 F'n'XJ1100 *
the one bad thing about my xs-- a "harley-esque" transmission.
i assume the boys at yamaha decided that they needed to build the thing "strong", so they sacraficed some "smooth"?
while on the subject--is their anything a person could do to help this out, short of buying new parts?79ish suzuki rm250
82 honda cb450sc
78 honda cx500
72 honda cb175
78 yamaha xs11e
While on the subject....
When in first and releasing clutch, it almost feels like the brakes are engaged. It really takes some rpm's (around 2000) to get moving, is this normal? The wheels move freely, so I don't think it is the brakes. It kills the engine if not revved before slowly releasing the clutch. Any thoughts?
Dupman
dasuchbe - But I was curious to you comment about recent oil changes???
Dupman - When in first and releasing clutch, it almost feels like the brakes are engaged. It really takes some rpm's (around 2000) to get moving, is this normal? The wheels move freely, so I don't think it is the brakes. It kills the engine if not revved before slowly releasing the clutch. Any thoughts?Mike * Seattle * 82 F'n'XJ1100 *
Re: While on the subject....
Dupman
Hard to putt-putt away, from standing start.JCarltonRiggs
I found my problem, after talking with PO, I was told the front brakes drag periodically. After jacking the front, the wheel was extremely hard to turn. Removed calipers,(pads were good) and found plenty of rust. Cleaned it reinstalled, took test run. World of difference, just when I thought it couldn't be the brakes, BAM! there it was. My first bike ride, it was excellent!
Thanks,
Dupman
