help with king and queen seat
  • help with king and queen seat
    I have a'79 xs1100 special and looking for a king and queen seat. I have been looking at a seat for a '80 xs1100, but not sure if it would fit on mine. Does anyone have any knowledge about these seats? Anything would be appreciated. Thanks.
    '79 SF Special (deer hunter special)
    '79 SF Special Full Dress (restoring)
    '80 SG Standard
    78/79 have TCI mounted on rear fender, 80/81 under seat.
    While 78/79 won't fit the 80/81 have not tried other way around.
    Will be going to my shop soon and will check if an 80 seat will go on a 79.
    Sure that someone will probably let you know before I get back.
    mro
    btw,
    Welcome to XS land!
      Thanks for the reply. I was bidding on ebay, but not sure if I should continue. Auction ends in a couple of hours, so I hope some one will know.
      '80 SG Standard
        Hey MRO,
        The 78E has the TCI in the rear fender skirt section, but the 79SF has it under the seat on the front leading edge of the inner plastic fender! The later SG seat has a different profile, more of a dip in the middle, so it might contact your side panels, it's not flat across the bottom like the 79SF OEM seat!
        Otherwise, Techmgnt, you should be able to make it fit, in case you do WIN the Ebay auction!
          Thanks for the info. I did win the seat on ebay, so we will see how good it will fit. By the way, what does TCI stand for. I am still learning about my bike, so any info is deeply appreciated. Thanks again for your guys help.
          techmgnt
          '80 SG Standard
            Transistor Controlled Ignition
            XS1100SF
            XS1100F
              Is that also know as the CDI? Thanks for the reply
              '80 SG Standard
                Hey Tech,
                What we have is a TCI, the black box that controls the ignition system, we do NOT have a CDI!! And so you will not want to get any aftermarket coils that are for CDI's, or you will BURN OUT your TCI!!
                For a great learning experience, would highly recommend you go to the MAIN FORUM PAGE, scroll down to the TECH TIPS, and READ, READ, READ!!! You'll be amazed at the info you find!
                  Ok. Thanks for the tip. I have no aftermarket items as of yet. I will take your advise and do some soon.
                  '80 SG Standard
                    CDI
                    Hi Techmgnt,
                    Whyncha post sooner? I have a K/Q/Hi-Rise seat off my XS11SG and I can't even give the ugly thing away.
                    To expand T.C.'s post,
                    TCI = Transistor Controlled Ignition.
                    while
                    CDI = Capacitor Discharge Ignition.
                    As has been said, totally different creatures.
                    Fred Hill, S'toon.
