For years I have suffered the brutality of buying tires at stealerships. It gets old spending $220 for a couple tires then having to pay almost that much again to have them mounted and balanced.
In the past couple years two sets I've bought out of 5 or 6 sets weren't even balanced properly and I had to take them back.
Add to that the pain of having to set up an appointment and put up with all the questions like "Whaddaya riding that old thing for? Are ya sure ya wanna spent $350 on a set of tires...heck the bike ain't worth much more then that."
Then a bike like my ZRX eats 180/55-17 radials like a 3 year old through a bag of M&Ms. As you know a ZR radial for a sportbike aint cheap.
So I mounted and balance my first set of tires today. It wasn't much harder than doing it on a bicycle!
I can't believe I've been suckered into paying people to do this.
First I bought two pieces of equipment for my shop. A manual tire machine from Harbor Freight that cost about $100. Then I bought a static wheel balancer on Ebay for $65.
I first saw the balancer at the track one day. Some serious racers were balancing their tires with a very simple yet most effective device. It was an ultra-low friction static balancer. If you're not familiar with these things ...it is simply two ABEC 5 or 7 grade bearings mounted on a couple pieces of angle iron. Two assemblies are used. Then there is an axle with stainless steel cones that effectively clamp your wheel. The temporary axle and wheel are cradled in the two bearing stands on a level elevated surface (I used to saw horses). Then it is a matter of utilizing gravity and a few wheel weights. Utterly ingenious!
The guys at the track say this is even a better way to balance tires than computer spin or bubble balance. After today I believe them. It took a little longer for the trial and error process of balancing the wheels but boy did it work.
After a test run out the highway Zilla is smooth as glass...at any speed. I can't believe the difference and I will never take any of my bikes to a dealer for tires again.
BTW you don't really even need the tire machine from Harbor freight to mount/dismount the tires. This can be easily done with 2 or 3 spoon type tire tools and a rubber mallet. But you will need a way to break the bead on the tire. The Harbor Freight machine does have a bead breaker.
The most impressive part of this project was the quality of balance. It seems like everytime I get new tires they ride very good but they are not perfect. There is usually a little vibe at some speed. I guess the stealership doesn't spend much time getting it perfect...close enough works for them. However close enough doesn't work for me.
If this low friction static balancer is good enough for the boys that ride 130+ (speeds up to 150 or more) and they are satified I think it will work exceptionally well for anyone.
Cg
I can't believe I've been suckered into paying people to do this.First I bought two pieces of equipment for my shop. A manual tire machine from Harbor Freight that cost about $100. Then I bought a static wheel balancer on Ebay for $65.
Cg
How does it work? Do you just give it a little spin and let it settle out with the heaviest side at the bottom and the stick a guesstimate wieght at the top?
