cant get xj1100 to 850k rpm
  • posthuman
    • 71
    stock XJ 13000 miles
    I can't even get it to 850k rpm
    just looses too much power, chokes to death or something, maybe leans out too much.. dunno
    example: third gear on freeway WOT, gets up to about 75+- mph and 800 +- rpm and goes no faster or rev higher
    I have read everything about performance on this sight I think
    I'll be slowly improving this machine with kerkers, airbox drillin' etc.
    XJ 1100
    XJ 550
  • strom
    • 1577
    • Slovenia, EU
    Adjust your cam chain tensioner.
    And sort your RPMs... 850k... even jets dont do that.
    8.5k, 8500, ....something.
    The engine should pull stock well into the redline.
    Unless you broke or bent a valve or something. Check compression, sync the carbs, adjust ignition timing,...
    LP
      Hey Strom,
      Take it easy on the guy, he just got his bike back from being STOLEN! The "Theft", may have overrevved it and possibly bent a valve or two?? Have you done a compression test since you got it back? The XJ's TCI does not have a rev limiter, so it should run well past 8.5 K rpm! Check your vacuum lines, especially going to the little vacuum sensor under the tank!
      Switch the petcocks to PRIME, and try it to see if it still fades. If NOT, then it's a fuel supply problem, the Octy may not be functioning properly, again, the vacuum hoses going to it!
      Good Luck!
      • lsippell
        • Sep 2003
        • 216
        • Mayflower, Arkansas
        I wish my XJ would turn 850,000 rpm!
        Louis
        "There is no mechanical problem so difficult that it cannot be overcome by
        brute strength and ignorance" And possibly some Mouse Milk!
        '82 XJ1100J
        LED Dir and running lights
        LED Tail/Brake lights (4) one flashing
        Modulated H/L
        PIAA Driving lights
        YICS Eliminated
        750 FD
        Yamaha Factory X-1 Fairing and Luggage
          I don't believe I wanna be sitting on ANYTHING spinning that fast!
          Post... when's the last time you checked/cleaned/changed your air filter? Mine would do the same thing with those PNM air filters... it just couldn't breath at those higher rpm's. Just another suggestion.
          • posthuman
            • 71
            thanks , good suggestion s all
            glad I could provide entertainment with a typo as well
            has a stock yamaha airbox filter
            XJ 1100
            XJ 550
