OK I am putting my hop up engine together and have a problem. There is a oil feed cover on the shifter side of the engine under that cover. I have used care to install it flatly but when I firmed up the lock tight-ed screws it cracked at the narrow end where the O ring is. I took the same part off my parts engine and used even more care and only seated the screws lightly and it still cracked at the same location. So now I have only one more of that part that is currently in my running engine. How the hell am I to install that oil supply cover to the trany shaft with out braking it???? Anyone know if that is a pressurized supply or gravity feed?? Can I supper glue the broker one back together after cleaning with contact cleaner and reuse it??? This is an important part that supplies oil to the trany shaft so it MUST work perfectly.
Anyone else have this issue after splitting the cases??
Rob
Rob
