Dressing Clutch Plates
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    I have the clutch out of my 1179 hop up engine and can see that the steel plates are not burnt but are rather smooth to the touch. Is this normal. i see the embossed "dots" on them but they still feel rather smooth.
    Same thing for the fiber plates. They are rather smooth. Should they not feel something like brake pads? If I am not mistaken the fiber plates can be "dressed" by giving them a light sanding to rough up the surface. What grit of paper should i use? Same for steel plates .. Can they be "dressed" and if so what grit of paper should be used to give them some added tooth?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • 81xsproject
    • 3185
    • Fortuna, CA
    They should be sanded up a bit. Go to the tip-maintanance, and check out the cluth refurbish thread.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • 81xsproject
      • 3185
      • Fortuna, CA
      here's the link
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • 79XS11F
        • 3563
        Thanks for the link. I didn't think to check in the engine section of the maintenance threads
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • MAXIMAN
          • Jan 2005
          • 1817
          I've sanded clutch plates before with ZERO luck. I have however had good luck replacing springs.
          But the best solution I found to a slipping clutch is two words?
          BARNETT KEVLAR
          • 79XS11F
            • 3563
            BARNETT KEVLAR
            and where might I be able to find one for Barnett clutch or plates for a bike as old as mine? you got a link?
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • MAXIMAN
              • Jan 2005
              • 1817
              Barnett Clutches
              Then click dealer for your state. You'll have to order through a dealer.
              • 79XS11F
                • 3563
                Thanks for the link
                Rob
                1978 XS500E
                1981 Suzuki GS1100
