2 questions...my #3 cylinder (pipe) isnt as hot as others.coil pickup seems fine ,getting fire to all 4 plugs ,traded 2and3 pug wires and #3 still not as hot ???in the carbs ??? other question ? i replaced my fuse block w/inline fuses 30amp for main and 10 for the rest ???is that a safe number for the others?
#3 cylinder /fuse
Tags: None
Two questions back, how are you determining that your #3 is cooler and what are the temps?The Old Tamer
_________________________
If there are more than three bolts holding it on there, it is most likely a very important part! -
Hey "Oxymoron" (Sober-Drunk)
Most likely it's the carbs, some junk may have gotten past the screen and into the pilot circuit partially clogging it!?
As for the uses, the Turn Signals use a 20A, more power draw for the Thermal flasher unit and such!
Before doing a carb teardown, you might try some SeaFoam, carb cleaner in the tank??
T.C.T. C. Gresham
spit on hand ,hand on pipe...#1hot #2hot #3warm#4 hot ......i will look for seafoam .thanks for both responses i will i will be back soon...Originally posted by Dragon Tamer
Two questions back, how are you determining that your #3 is cooler and what are the temps?wish me luck,because i am lacking in the skillsComment
it could be an adjective describing a nounOriginally posted by soberdrunk
thanks for your time and i will check it out
