idle mix o-ring source
  • 77crewcab
    • 87
    Anyone know of a source to get just the o-ring for the idle mix screw. I could probably get some at work but hate to have to deal with the parts idiots if I don't have to.
    80 XS1100LG
  • Brian_D
    • 355
    • Gardner, KS
    77crewcab,
    can pick up both the o-ring and washer from MikesXS
    Part #48-5012 $4.00 USD /3Pc. Set
    Of course, need to order one for each carb and just throw away the plug cover.
    • 77crewcab
      • 87
      I saw that but am only needing the o-rings. I guess I'll go through our parts dept at work and see what I can come up with. Also anyone know where to get the washers to adjust the slide needle on an 80. Tried the hardware store and they didn't have anything that small.
      80 XS1100LG
        ACE had screws and washers down to #0 in my town. They are in just ONE bin, and went from #4 to #0.
        I think a #4 or #2 should work, though you may have to sand the outer diameter down a bit to fit.
        Ray
        • 77crewcab
          • 87
          Thanks I may have to try ACE though the one we have hear isn't very large maybe they will have what I need.
          80 XS1100LG
          • HobbyMan
            MeatHead Idiot "GURU"
            • 1801
            • Colleyville, TX
            ACE has an oring that will work. I lost one and after about 30min of searching at ACE, I found one in a corner somewhere. Just look around.
            Acta Non Verba
