clutch plate change
  • oldnortonrider
    • 448
    clutch plate change
    I think before long, I'm going to be due to install, and change out the clutch plates. Possibly, new springs, too.
    Am I gonna need a special tool to do this?
    JCarltonRiggs
    • 5069
    A big socket. Someone help out here...is it a 28 mm (about a 1+1/8 inch)?
      Hey Norton, and Skids,
      That info is in the tech tip on adding an extra Steel plate, you might want to think about doing that while you're in there Norton!
      And impact wrench makes getting that large clutch basket nut off, but you'll still need to wedge the rear wheel when tightening it. You'll need a low scale ft/lb torque wrench, or an inch pound one, the clutch basket spring bolts only needs 7 ft/lbs!
      • Mike F
        • 99
        • Amesbury (next to Stonehenge)
        Hey Norton
        You can also do the clutch change without draining the oil if you have the bike on the side stand.
        don't forget to line up the cogs on the back of the basket before you start retightening everything. I broke my oil pump idler gear 'cos I didn't check. Ouch!
        Mike Farnworth
        XS1100 E & XS1100 Sport Project
        • oldnortonrider
          • 448
          I can't find the tech tip about the extra steel plate?!
          Had seen something about "an extra steel plate", on another post, here, a while back. Looked for additional information then, and couldn't find it.
          JCarltonRiggs
            Hey Norton,
            Folks forget that another and different set of tech tips are directly from the MAIN FORUM PAGE, just scroll down and you'll find them. It was in the REPAIRS, Engine section!
            Extra Steel clutch plate tip
            • oldnortonrider
              • 448
              A superb tech tip; pictures, complete explanation, etc.
              Muchly appreciated.
              I had looked under "clutch", "transmission", "modifications"; everything except "engine". ..........................guess it just never dawned on me, that it might be part of the "engine";
              duhhhhhhhhhhhhhh .....................
              Thank you very much, again, for the tech tip, and for your effort(s)
              putting it together
              JCarltonRiggs
                • 5069
                Yeah, that tech tip is a keeper.
                • HobbyMan
                  MeatHead Idiot "GURU"
                  • 1801
                  • Colleyville, TX
                  Can you still buy OEM clutch plates? And are they expensive?
                  Acta Non Verba
                    PartsnMore, $5.00 ea, $40 for a set of 8, free shipping! Throw in a set of HD springs while you're at it! A fellow Xsive is selling extra Steel plates, had a couple left , check the Member's Forum. Otherwise, from BikeBandit, about $8.00 ea for Steels!
