bad to worse
  • SiP
    • 438
    • Medicine Hat, Canada
    bad to worse
    Ok - I posted on here about my snapped spark plug - the my snapped extractor in the spark plug hole.
    I've bitten the bullet and taken the head off, it's now in the machinists getting cleaned and heli coiled - That's the good news.
    Here's the kicker and if I had the ability I would indeed be kicking my own arse for being such a f@#*ing dimwit.
    While stripping the inlet cam off I dropped one of the bearing cup washers straight down the timing chain hole !!!!!
    There's no sign of it and fishing around with a magnet doesn't produce anything - please please please don't tell me I now have to do a complete engine strip. It's only little it might be OK?? is there any other way of seeing what's in the case?
    help
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
  • SiP
    • 438
    ebay carb kit
    By the way could someone (more knowledgable than me - ie everyone) check out this lnk for a carb kit and tell me if it's worth it/any good please.
    My bikes an '81 H by the way.
    http://cgi.ebay.ca/YAMAHA-80-81-XS11...QQcmdZViewItem
    Si Parker
    '81 XS1100H
      Hey Sip,
      Are you familiar with the Yamaha Online Microfiche site, if not, you can find it in the LINKs section! Go there, to the camchain section for your year/model, and you'll see the chain tensioner has this shelf as part of it's design, it may have fallen there, and with oil, could have just stuck!
      You can pull the bottom tranny pan off without pulling the engine and you may find it has fallen down into it!? This is why they say to stuff a RAG down into the cam chain tunnel to prevent this!
      Carb Rebuild Kit
      Carb Rebuild Kit - Fits: XS650SG-SL (1980-84) stock Mikuni 34mm. CV carbs
      Kit Contains : Push-in Float Valve assembly with O-Ring, Carb rubber passage
      Plug & Float bowl Gasket 3F7. Made in Japan - 1 kit required per carb.
      Part #48-1408 $12.00 USD /Kit
      MikesXS has the above kit. Free shipping with order over $35.00! Unless you need to replace your jets and choke plunger, usually not, then this is all you really need, just be careful when removing the pilot screws so as not to loose the little washer/o-ring around the tip down in the tunnel!
      GeorgeFix sells good stuff, but it's not all needed with a regular rebuild/cleaning! BTW, don't use the rubber pilot jet tower plug!
      • pggg
        • 1609
        • NZ
        Sip, the washer in the sump won't be a problem, the oil pump is screened with mesh, the washer will sit in the sump recess, but if you wanna get it out, you only need unbolt the sump pan. 14 bolts. 77 bucks for carb kits, waste of money if the carbs are all O.K. especially if those kits have non-mikuni parts, but maybe worth it if the carb components are all seized and corroded - which won't be the case if the bike's runnin O.K. Individual mikuni jets are about 5 or 6 bucks each.
        • SiP
          • 438
          you guys r great, that's good news!!
          I checked out mikes xs, and he only seems to supply for 650's. Does it not matter with the carbs?
          Si Parker
          '81 XS1100H
          • 81xsproject
            • 3185
            • Fortuna, CA
            no, those will work. TC know his stuff and MikesXS is a great way to save money on items that overlap models.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • mro
              • 4276
              • Hayward, California
              Off with her head
              Good time to change the cam chain too.....
              mro
                Only dropped one washer down the hole? You need to remove the oil pan first. Then, lay on your back on the left side of the bike with your feet towards the front wheel. Reach over with your right hand and put it up inside the open hole with your fingers forward. Chances are you will put your hand right on the washer. If you don't find it immediately, pat around with your fingers.
                BTDT, DAMHIKIJD
                • mro
                  • 4276
                  Kinky aren’t they
                  Posted by a Canadan
                  Only dropped one down the hole? You need to remove the pan first. Then, lay on your back on the left side of the bed with your feet towards the front . Reach over with your right hand and put it up inside the open hole with your fingers forward. Chances are you will put your hand right on it. If you don't find it immediately, pat around with your fingers.
                  mro
                  the Menace
                  • oseaghdha
                    • 1075
                    • N43.02.5,W88.14.2
                    Originally posted by pggg
                    Sip, the washer in the sump won't be a problem, the oil pump is screened with mesh, the washer will sit in the sump recess, but if you wanna get it out...............................
                    And you do want to get it out, don't you SIP?
                    Seriously, remember the "Anything that can wrong will go wrong" rule.
                    Good Luck with that.
                    O
                    XS1100SF
                    XS1100F
                    • SiP
                      • 438
                      Again - thank you. However you've sparked another question
                      good time to do the cam chain..
                      How can you do it without splitting the case - I thought the chain was endless?
                      Si Parker
                      '81 XS1100H
                      • mro
                        • 4276
                        Cam chain riviting tool
                        cut chain, link or wire chains together, feed through, rivit new chain.
                        mro
                        btw, easier said than done, but not too hard
                        mro
                        • mro
                          • 4276
                          Need to order master link with new chain. Most will not come with it.
                          mro
                          • prometheus578
                            XS-XJ Super Guru (RESIGNED)
                            • Aug 2004
                            • 4012
                            • Olympia , Wa.
                            (I thought I was the only boob who ever did that! Still down in the bowels of the beast somewhere, too)
                              Re: Cam chain riviting tool
                              mro
                              mro
                              Unless you have your Bro-n-law assist you, then you'll be sure to tear things up! Just ask Randy!
