Just noticed that the rubber boot on the driveshaft is cracked. What is the common way of replacing it. It appears to be similar to a CV joint boot wondering if any driveline shop could replace it.
driveshaft boot replacement
Hey Crew,
It's no where near that complicated, it's just a dust/water cover, no oil or grease inside there! There are 2 spring style clips that hold it onto the middle gear and the swingarm, just unhook those, and pull it off away. The trick is you will need to unbolt the Ujoint from the Middle Gear to get it off and to put a new one on. You may be able to clean it up, and seal it with some Plastidip rubber coating, or other sealant of your choice!
T.C.T. C. Gresham
How nature points out the folly of men! -
I have 2 boots to replace on my two bikes. Got them from Bike Bandit ($36 each IIRC).
I'm hoping they're not too difficult to replace.
Remove rear wheel and rear drive, slide driveshaft rearward a bit, remove/replace boot, put it all back together?
On the triple site someone mentioned removing all the motor mount bolts but one and tilting the engine in the frame to get the boot out.
Mine will be done when I do the 2nd gear fix (E) and the big bore kit (LG).Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Hey Crew,
It's under Rear Arm, Rear Cushion section!
T.C.8: BOOT,RUBBER 22738-001 $34.98
9: SPRING,TENSION 354717-001 $4.42
10: SPRING,TENSION (USA) 354716-001 $5.11T. C. Gresham
