Lighten UP!
    Well,
    I've had a few days off, went to the muffler shop, they DON'T do bends for out of shop work, only on what they do/put on!
    I showed the guy the photo of the bending jack from Northern Tool, and he said that it should work for the 16 gauge pipe. He also recommended filling with SAND(Thanks Rob), said that's what they do at the SHIPYARD. Sounds like a pretty simple way to keep it from kinking/buckling! SO...I may get to play "OCC" afterall! The 12ton one that handles up to 2" is only $99.00, the 16 ton that goes to 3" is $179.00.
    For simplicity, I'm only thinking of make 4 into 2's, but trying to mimic the Jardine Spaghetti style for more balanced effect WITHOUT the crossover pipe. So, this way, I should only need to use the smaller bender, essentially just making the headers, and welding them into a collector. Then I can fit some aftermarket mufflers, or even get some SS sheet, and roll my own?? We'll see!
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      Stainless Pipes
      Hey T.C. I will buy a set of pipes from you If they are all stainless. I like my 4-2 jardines now and will be doing a big bore eventually. Keep me in mind....chop
      MDRNF
      79F.....Not Stock
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        from the u.k.
        these are the best I have seen. I like the cross-over location also, because I can mount hidden monoshocks if I had a set of these....hint hint
        MDRNF
        79F.....Not Stock
        • Brian_D
          • 355
          • Gardner, KS
          #34
          TC,
          After reading the following threads on Maximan's bike, I've been wishing that someone (more knowledgeable than me) would start producing or bending new performance exhaust headers (4-2 and 4-1) for our bikes. Perhaps Maximum and Pat Kelly can provide some input on dimensions and design for the best 4-1 and 4-2 headers.
          Oh, and count me in for 1 exhaust system of each variety!
          • DeanR
            • Jan 2005
            • 1490
            • Finger Lakes NY
            #35
            TC, I like my exhaust but you have me thinkin' too!
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
