Source for rings?
  • Incubus
    • Aug 2006
    • 1003
    • Austin TX
    Source for rings?
    Does anyone know where I can find standard size aftermarket rings? I know they are still available through Yamaha, but at a breathtaking price. Does anyone know any rings that cross? Or at least the specs (diameter and thickness) so I can see who might offer the same spec rings for different machine?
    Thanks
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    • 1914
    I would suggest this listing rather then the standard rings unless you are starting out with brand new cylinders.
    http://cgi.ebay.com/ebaymotors/New-Y...QQcmdZViewItem .
    • Incubus
      • Aug 2006
      • 1003
      • Austin TX
      I saw those, too. But would I have issues putting OS rings on standard pistons in standard cylinders? Normally I would think I'd have to get .25 OS pistons and have the cylinders bored out to use these. Can I use these just to take up the slack for years of wear?
      Thanks.
      1969 Yamaha DT1B
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        That's what I used a few years back when I rebuilt Tsunami - 1st over rings on the standard pistons.
        Ken Talbot
        • Incubus
          • Aug 2006
          • 1003
          • Austin TX
          Works for me. I have to admit I found the price quite attractive......
          Thanks,
          Patrick
          1969 Yamaha DT1B
            • 5062
            How is that working out, Ken?
              IF the eBay set goes too high!
              They are still available from other sources as well:
              BikeBandit: XS1100E
              7: PISTON RINGSET 1ST
              (ALTERNATE PARTS) 35277-001 $42.09
              Also, using www.cycle-parts.com
              1 3J2-11610-10-00 PISTON RING SET 1ST OS $40.56
              *BUT* they only accept orders of $75.00 or more, so you'd need to order more!?
              3J2-11610-10-00 or 2H7-11610-12-00
              • excess11
                • Oct 2004
                • 256
                • Rockville Md.
                Idea!!
                Usually you can trim rings to size. I don't know if it can be done with the rings in our bikes or not??? Insert the rings into the cylinder square them up with a piston about mid cylinder. Then use a feeler guage to measure the end gap of the rings. There is usually a spec for this distance. The rings can then be trimmed to correct spec's. I think size one over should work!!!!
                Dan ( A.K.A.- MacGyver )
                • Ken Talbot
                  • 4251
                  • Revelstoke, BC
                  Never had it on a dyno, but it seems to have all the power it needs, mileage is good, no unexpected engine sounds. I think I've got 5 or 6 years on the rebuild, might have to check the compression one day just for something to do.
                  Ken Talbot
