Source for rings?
  • Incubus
    • 1003
    • Austin TX
    Source for rings?
    Does anyone know where I can find standard size aftermarket rings? I know they are still available through Yamaha, but at a breathtaking price. Does anyone know any rings that cross? Or at least the specs (diameter and thickness) so I can see who might offer the same spec rings for different machine?
    Thanks
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    I would suggest this listing rather then the standard rings unless you are starting out with brand new cylinders.
    http://cgi.ebay.com/ebaymotors/New-Y...QQcmdZViewItem .
    • Incubus
      • 1003
      • Austin TX
      I saw those, too. But would I have issues putting OS rings on standard pistons in standard cylinders? Normally I would think I'd have to get .25 OS pistons and have the cylinders bored out to use these. Can I use these just to take up the slack for years of wear?
      Thanks.
      1969 Yamaha DT1B
        That's what I used a few years back when I rebuilt Tsunami - 1st over rings on the standard pistons.
        • Incubus
          • 1003
          • Austin TX
          Works for me. I have to admit I found the price quite attractive......
          Thanks,
          Patrick
          1969 Yamaha DT1B
            How is that working out, Ken?
              IF the eBay set goes too high!
              They are still available from other sources as well:
              BikeBandit: XS1100E
              7: PISTON RINGSET 1ST
              (ALTERNATE PARTS) 35277-001 $42.09
              Also, using www.cycle-parts.com
              1 3J2-11610-10-00 PISTON RING SET 1ST OS $40.56
              *BUT* they only accept orders of $75.00 or more, so you'd need to order more!?
              3J2-11610-10-00 or 2H7-11610-12-00
              • excess11
                • Oct 2004
                • 256
                • Rockville Md.
                Idea!!
                Usually you can trim rings to size. I don't know if it can be done with the rings in our bikes or not??? Insert the rings into the cylinder square them up with a piston about mid cylinder. Then use a feeler guage to measure the end gap of the rings. There is usually a spec for this distance. The rings can then be trimmed to correct spec's. I think size one over should work!!!!
                Dan ( A.K.A.- MacGyver )
                  Never had it on a dyno, but it seems to have all the power it needs, mileage is good, no unexpected engine sounds. I think I've got 5 or 6 years on the rebuild, might have to check the compression one day just for something to do.
