Gas tank rust removal
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    Look for sodium carbonate at your local pool supply store. Genrally most PH+ products are actually sodium carbonate( washing soda)
    Acta Non Verba
    • Douglas Money
      • Jun 2006
      • 180
      • Braidwood IL
      It is actually hard to find. I use the Arm & Hammer laundry soap, but it is not the best one. I found it at Super K-Mart. Just make sure of the ingredients for what you get. Good Luck.
      1979 XS1100F (runnin the wheels off it)
      1979 XS650 (ran the wheels off it)
      1976 CB550F (ran the wheels off it)
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        Cleaning gas tanks
        Ok
        This may draw some scowls and jeers but it works.
        Remove the sending unit, petcock(s) etc.
        Add adout 1/4 gallon water and dish soap and.....
        gravel.
        Shake the ever luvvin you know what out of it.
        When you have shaken it enough, shake it some more.
        Cleanup is reverse, then hose it out, pour in about a cup of WD40, shake.
        Dump that, add a pint of gas, shake and dump. Repeat until it comes out clean.
        It's rude and crude but it works.
        Use small pea gravel or shot. The idea is to get some abrasive in there to scour the mung off.
        No nasty chemicals to ruin the paint either.
        I have done this with excellent results.
        YMMV, use inline filters.
        XS1100SF
        XS1100F
        • HobbyMan
          • 1801
          • Colleyville, TX
          Whatever you do, do not put large dense objects in your tank to shake. They will most definitaley dent the tank or the inverse.
          Acta Non Verba
          • ccogswel
            • Jun 2005
            • 302
            • Bowling Green, Ky
            Well I was never able to find the Arm&Hammer Super Washing Soda. But with your all's help I did get the PH+ that is 100%Sodium Carbonate. I plan on starting it this weekend. I'll take some before, during and after pics to show everyone. So I guess in 3 or 4 days I should see some results. I got the PH+ from the local pool store for $3.99 for a 2lbs bottle. Not a bad price. Thank you all for the help. I'll post back in a few days with results.
            Chris
            79 XS1100 Standard aka: Mutt
            Gimme Fuel Gimme Fire!
              • 8061
              With the stuff you're using, you'll need to use less than you would the washing soda. Probably about a third.
              The nuts & bolts or gravel trick may be a good prerequisite to getting it going.
              • excess11
                • Oct 2004
                • 256
                • Rockville Md.
                Rock-on!!!
                Rocks and water does work well to remove the scale and knock down most of the rust. It is a good place to start and will help the process along should you follow with the chemical treatment. Dime sized rocks are all I have used nothing that could produce a dent. I put about 20 of them in the tank with some water and then shake every possible direction. Then put the garden hose in the filler and let the water run until clear. It will remove alot of stuff,you will see all kinds of junk floating out of the tank.
                Dan ( A.K.A.- MacGyver )
                  • 8061
                  I meant only to use it to knock down the big stuff. I use nuts and bolts mixed with WD40. After that, use electrolysis.
