1982 XJ Carb parts interchange??
  • underdog57
    • 321
    • Alburgh , Vermont,054
    Pretty much just need float needle and seat , So was wondering
    if the 1980 and 1981 xs1100's had the same press in needle/seat ...Plus several xs 650's ...
    And if this carb needs to have the rubber plugs over the pilot jet hole ?? They had none when I took it apart ..
    I did try to look this up , but this carb was a tad sketchy on info ..
    Now what someone pull reams of data up !!!
    The pilot jets were 45's so looks like someone changed them from 47.5 . The mains are 112.5 so looks like the carbs are original ..
    Thanks
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
  • red bandit
    • 955
    • central michigan
    80 and 81 float needles and seats are the same. You shouldn't have to replace the seats, they usually are ok.
    If you don't have a hole connecting the main jet tower and the pilot jet tower then you don't need the rubber plugs. If you have a hole,then you need the plugs.
    Standard pilots jets are 42.5 for the 80-81, not 45 or 47.5
    I've seen main jets for the 80-81 from 110 to 120 and everything in between.
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
    • underdog57
      • 321
      Will order
      Thanks Red Bandit ,
      I can save the needle valve seats , but I did smoosh them a little,they were so stuck with tar ... wish I was more carefull with them !!
      Will look at the main/pilot for a hole or not to see if they need the plugs ..
      Bob
